    Print a missing piece.
    layout
    2 Posts 2 Posters 489 Views 2 Watching
      cellomagalhaes
      I'm having the following problem.
      I have an HP 3425 that works perfectly.
      When creating a project in 3 layout, print command, but is cutting a piece of the project.
      oves the drawing and the margins to one side.
      The scale is correct, as measured with a ruler after printing.
        Do you mean that the printer is not printing the edges of your project? It could be that the printer's margins are wider than those you have set in LayOut. You can reset the margin width in Document Setup in LO to suit the margins of the printer.
