    Kerkythea Materials
    6 Posts 3 Posters 6.5k Views 3 Watching
    • M
      Meike
      Probably I'm posting in the wrong subforum, but it's al about the materials I can download at the download section of KerkyThea's own website.
      There are several choises of materials and models, for me it's important how to use the materials. Where do I have to place the zip-files in the sub-folders to use the materials in Kerkythea it selfs ? Or is it also possible to use all the materials in SketchUp, without the loss of qualtity instead of using the materials in Kerkythea ?
      I just found out to use imported materials in SU as Unique textures, but I'm not sure about the quality of KT-materials exporting them to SU or to use original SU materials ?
      • numbthumbN
        numbthumb
        You might find this useful: http://www.kerkythea.net/joomla/index.php?option=com_wrapper&Itemid=76
        Search Kerkythea Rendering System Forum Index -> Tutorials -> How do I download/install materials?
        Comfortably numb...
        • GaieusG
          The Kerky forum is wrapped into a frameset or what so you cannot link to a topic by copying the URL. Here is the link to that particular topic:
          http://www.kerkythea.net/phpBB2/viewtopic.php?t=9700
          Basically you go to file>install library, select the downloaded zip file and the rest should be done by Kerky.
          • numbthumbN
            numbthumb
            I´ve noticed that - so I tried to link to the topic "manually" 😄
            Hope Meike wasn´t too confused.
            Comfortably numb...
            • M
              Meike
              Nope, I'm not confused... 😄
              It's only that my computer or Kerkythea is struggling to install the new library's !
              And because I've nothing to do now: Does anyone known a good carbon-fibre texture... ? 💚
              I've tried several textures from Google-images, but with every texture I use, I got tiles or I have to stretch it....but then the texture is to wide/big for realistic texturing my component.
              • numbthumbN
                numbthumb
                This: http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=88 ?
                Comfortably numb...
