    Recommend Plugins
    9 Posts 5 Posters 787 Views 5 Watching
    • A
      acidblue
      Hi There!
      I'm a new user of SketchUp and would like to know whats everyones recommended plugin/script that every should have, especially for new users.
      Ones I have are:
      Round Corners from the Fredo6 Collection. http://forums.sketchucation.com/viewtopic.php?f=323&t=20485
      SU2KT which is a script for exporting models to the Kerkythea Renderer. http://www.kerkythea.net/joomla/
      • A
        ArCAD-UK
        If you are going to produce section cuts then SectionCutFace by TIG is an absolute must have!
        Do a search for Dline, which is also a very useful basic addition to the general toolset.
        Other than that there seems to be plugins for almost anything and if there isn't you can ask and someone may come up with a workaround or tip to help you achieve what you want.
        • mitcorbM
          mitcorb
          Absolutely have "Weld" on board. Also, "Mirror Selection". If you have not already done so, activate the native Sketchup extensions in Window>Preferences.
          Edit: Since you are familiar with Fredo6 collection, consider Joint Push/Pull. I also recommend that you become familiar with basic native tools and get some mileage with the "knitting" process, learning the behavior of the inference engine.
          • numbthumbN
            numbthumb
            It all depends on what kind of work you´re using SU for - if, for instance, you´re not interested in organic modeling, than you probably won´t need Artisan.
            Getting to know SU native tools first would be a good start IMO.
            Anyway, you might want to take a look at this topic: http://forums.sketchucation.com/viewtopic.php?f=323&t=16909
            Comfortably numb...
              Seems you have a list of indispensables here 😉
              • mitcorbM
                mitcorb
                @Pilou:
                I have tried 3 times to click on your link "indispensables". It says "You are not authorized to view this forum"??
                • A
                  acidblue
                  @mitcorb said:
                  @Pilou:
                  Funny, it works for me.
                  Try logging out then log back in, maybe it's a cookies thing.
                    Ah Sorry 😳 : it was for the French Section (but no problem there is a list inside of lines links 😉
                    For access just press "User Control Panel" / "Users groups" / and select "Francais"
                    • mitcorbM
                      mitcorb
                      No problem. I knew about the "Must Have Plugins Visual Edition." However, this ain't about me. Acidblue gets his info-that's what counts. Merci 👍
