    Hidden function in DC
    5 Posts 3 Posters 1.4k Views 3 Watching
    • P
      probuild
      hello guys, I am new to DC, spend all day to make a kitchen cabinet, which changes in sizes length height and depth, with success,
      in component option window I want the user to have a text box with the option to hide the door of the cabinet box or not
      in the component attributes window I succeeded with this on the child component level (behaviors hidden), but how do I transfer this to the parent component level, so the user can choose the option in a text box in the component attribute window
      has anyone already done this? and is it possible to have it in the attribute onClick also
      can I combine the two?
      resume what I want,
      when opening component options window:
      the user can choose from a txt box, length, height and depth of the cabinet (this I have)
      but I want an extra text box where he can choose door hidden or not
      and if possible together, if he clicks on the door it disappears or reappears
      thanks in advance and sorry if these questions are to simple for you guys
      regards,
      guy
      • jeff hammondJ
        jeff hammond
        you should do it the other way.. put the choice in the parent level then pass is down to the child with =parent!(attribute)
        here's a quickie example.. the parent accepts the depth & visibility then passes the info down to the respective child.
        dc_parent_example.skp
        dotdotdot
        • P
          probuild
          tx very much Jeff for your quick reply and for the effort to make an example
          what about the onClick?
          I encountered also a problem this morning when I opened my saved component which I made yesterday
          the parent component was gone and it opened as separate components, I saved it yesterday with save as (on the right click)
          what did I do wrong?
          • J
            Jim
            In this case, you should File > import the model rather than File > open it. (You can also drag&drop the model from your file browser into SketchUp.)
            Typically, I do all the DC work on a "working copy" of a DC. Then when it is ready to use, that is when I export the Component using the right-click Save as option.
            • jeff hammondJ
              jeff hammond
              yeah, you can do that too using SET()
              in this case, i just added an onClick behavior to the parent then entered Set("door_vis",0,1)
              (and if you prefer, you can use TRUE or FALSE instead of 0 and 1)
              so now, in this example, the door can be hidden via the Component Options window's dropdown list OR with the onClick
              dc_parEx_withOnClick.skp
              dotdotdot
