    Rounded edges
    3 Posts 2 Posters 279 Views 2 Watching
    • X
      Xoda
      I was drawing rounded edges for a counter top and ran into difficulty. I rounded the edge off off one side but could not round the edgeon the side 90 degrees from the first
      • GaieusG
        Hi Xoda and welcome!
        Indeed, that's one thing that needs some strategy already. I suggest you to read through this tutorial first and try to do it manually to (also9 learn how SU works:
        http://forums.sketchucation.com/viewtopic.php?f=18&t=3631
        Then when you are confident that you "could" do it if you wanted, have a look at this plugin:
        http://forums.sketchucation.com/viewtopic.php?t=20485
        • X
          Xoda
          thanks i will give it a try
