Rounded edges
I was drawing rounded edges for a counter top and ran into difficulty. I rounded the edge off off one side but could not round the edgeon the side 90 degrees from the first
Hi Xoda and welcome!
Indeed, that's one thing that needs some strategy already. I suggest you to read through this tutorial first and try to do it manually to (also9 learn how SU works:
http://forums.sketchucation.com/viewtopic.php?f=18&t=3631Then when you are confident that you "could" do it if you wanted, have a look at this plugin:
http://forums.sketchucation.com/viewtopic.php?t=20485 -
thanks i will give it a try
