    Slider puzzle
    13 Posts 4 Posters 2.1k Views 4 Watching
    • F
      fransko
      Who can help me with this task
      the blocks can not rotate so using only the x and y axis
      to move
      same as this game
      ERROR: The request could not be satisfied
      (flash.hoodamath.com)
      slidergame.skp
      • N
        Naththagr8
        Here's a quick model. It's not the best, but I'm not a person of code. It's a bit bouncy and some are stubborn, but that can be fixed, and I'm not in the mood currently. If someone wants to, go ahead and fix it, but I'm sure a different version will come about.
        slidergame_v0.1.skp
        Naththagr8
        Top Headlines: "Beverly Hills 90210, Cleveland Browns 3"
        • F
          fransko
          thats a nice solution i was thinking it doesn't works with script
          but you let see that it is posible
          verry nice and thanks
          (exusses for bad language)
          • M
            Mr.K.1
            An even simpler solution
            slidergame.skp
            • F
              fransko
              can you explane about giro ?
              please
              • N
                Naththagr8
                Ah, yes, forgot about that... Simplicity!
                Any object connected to a gyro joint will have the axis the joint was drawn on be locked.
                Naththagr8
                • S
                  sketchyKev
                  Mr.K beat me to it! ๐Ÿ˜ฎ
                  My version has a gyro too, but I have added a hidden layer with chamfered corners which makes it less likely that the corners will catch on each other. You can pretty much "slam dunk" the pieces into place, but to be honest it not much improvement on Mr.K's version which is pretty good already.
                  slidergame_v03e.skp
                  • F
                    fransko
                    is it posible when you solve puzzle in level 1 you can go to level 2 ? and so on
                    slidergame level 1 - 10.skp
                    • M
                      Mr.K.1
                      Well here is a quick and crude solution, it just checks if all the named blocks are positioned beyond the border.
                      • S
                        sketchyKev
                        Once again some really impressive ruby coding from Mr.K! I like the use of two gyros and cylinders for the corner squares. It all works so well! ๐Ÿ‘
                        • F
                          fransko
                          I thank you for the nice solution i am working now for the levels 11-20
                          here are the levels 1-10 with mutch help from you thanks
                          i set the game in the warehouse
                          slidergame level 1 - 10a.skp
                          • F
                            fransko
                            here is level 11-20 will be continued
                            slidergame level 11 - 20.skp
                            • F
                              fransko
                              here is level 21 - 30 will be continued
                              slidergame level 21 - 30.skp
