    Slider puzzle
    13 Posts 4 Posters 2.1k Views 4 Watching
      Mr.K.1
      An even simpler solution
      slidergame.skp
      • F
        fransko
        can you explane about giro ?
        please
        • N
          Naththagr8
          Ah, yes, forgot about that... Simplicity!
          Any object connected to a gyro joint will have the axis the joint was drawn on be locked.
          Naththagr8
          Top Headlines: "Beverly Hills 90210, Cleveland Browns 3"
            sketchyKev
            Mr.K beat me to it! ๐Ÿ˜ฎ
            My version has a gyro too, but I have added a hidden layer with chamfered corners which makes it less likely that the corners will catch on each other. You can pretty much "slam dunk" the pieces into place, but to be honest it not much improvement on Mr.K's version which is pretty good already.
            slidergame_v03e.skp
            • F
              fransko
              is it posible when you solve puzzle in level 1 you can go to level 2 ? and so on
              slidergame level 1 - 10.skp
                Mr.K.1
                Well here is a quick and crude solution, it just checks if all the named blocks are positioned beyond the border.
                  sketchyKev
                  Once again some really impressive ruby coding from Mr.K! I like the use of two gyros and cylinders for the corner squares. It all works so well! ๐Ÿ‘
                  • F
                    fransko
                    I thank you for the nice solution i am working now for the levels 11-20
                    here are the levels 1-10 with mutch help from you thanks
                    i set the game in the warehouse
                    slidergame level 1 - 10a.skp
                    • F
                      fransko
                      here is level 11-20 will be continued
                      slidergame level 11 - 20.skp
                      • F
                        fransko
                        here is level 21 - 30 will be continued
                        slidergame level 21 - 30.skp
