    [Plugin] Contour Lines (Didier Bur)
    12 Posts 8 Posters 22.1k Views 8 Watching
    • charly2008C Offline
      charly2008
      So far I've used this plugin only for terrains. One can also use it for the even division of geometric bodies or faces. I've only just found out by chance.
      Charly
        Better if you give the address of the plug: contour lines ☀
        It was not on the list 😉
          charly2008
          Hi Pilou,
          I checked again and found also a similar plugin "Contour Maker" from TIG. Here are both links:
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=83
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=82
          Charly
            Funny plugs indeed 😎
            • 66searcher6 Offline
              66searcher
              @charly2008 said:
              Hi Pilou,
              Charly
              what's the differences between these plugins?
              http://hamidtoliat.deviantart.com/
                @66searcher said:
                @charly2008 said:
                Hi Pilou,
                Charly
                Of course mine is better 😲
                Test both they are slightly different 😉
                • F Offline
                  fossa
                  What plugin did you use to do the piping on the pyramid?
                    charly2008
                    Hi Fossa,
                    there are also some slightly different tools.
                    Charly
                    • F Offline
                      fossa
                      Thanks. I'll look into those. Been needing a good pipe tool. Sketchup work around here is slow so it just wasn't on the top of the list.
                        Ben Ritter
                        I've recently tried this ruby script and it doesn't create any contour lines. Does the surface have to be a group or individual faces? I've tried both, without any success.
                        Ben
                        • 3 Offline
                          3eighty
                          Just wanted to say the Ruby Plug=in Library is a very nice thought out and designed site..So simple to use...Thank You..
                          • Didier BurD Offline
                            Didier Bur
                            You can select individual faces in the model space or individual faces in the context of a group (but not the entire group itself)
                            Please post here what the Ruby console says when using the tool.
                            Regards,
                            DB
