    [Plugin] FredoTools::ConstructFaceNormal - v1.3a - 20 Jul 11
    3 Posts 3 Posters 21.4k Views 3 Watching
    • fredo6F Offline
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      ConstructFaceNormal is a small standalone script which will put a construction line along the normal at the barycenter of each selected face.
      Length of the construction line is just the average of the distance of the face contour to its barycenter
      http://forums.sketchucation.com/download/file.php?id=49285
      ConstructFaceNormal is now installed as part of FredoTools.
      See the main post for this plugin for Installation
      http://forums.sketchucation.com/download/file.php?id=49286
      No user manual (see section Quick Startbelow)
      • Language: English and French
      • Menus: by default, it is installed in Tools > FredoTools > Construct Face Normal and also appears in the Contextual menu when there is at least one face in the current selection
      • Icon toolbar: Fredo6 Tool. Icon not shown by default
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49284
      http://forums.sketchucation.com/download/file.php?id=49288
      • Select one or several faces (edges and other elements will be ignored)
      • Call the Plugin on the selection (main menu or contextual menu “Construct Face Normal”)
      • Construction Lines are placed at barycenter of each selected face
      http://forums.sketchucation.com/download/file.php?id=49289
      ConstructFaceNormal 1.3a - 20 Jul 11: Part of FredoTools. No functional change
      ConstructFaceNormal 1.2a - 26 May 11: Position the construction lines at the real centroid of the face
      ConstructFaceNormal 1.1a - 25 May 11: Initial version
      • mitcorbM Offline
        mitcorb
        Hi, Fredo:
        I like the concept. A good standalone "simple" tool. It will make a good companion to Chris Fullmer's Three Lines Tool, which places a normal on edges, among two other functions.
          I believe there is somewhere a plug who convert Construction lines in real lines 😉
          for some fun exploration 😄
          OK this is Lines Converter by Rick Wilson
          Conctruction Lines <--> Lines 😎
          Projection by Didier Bur, Random Painter By Chris Fullmer
          1 Reply Last reply Reply Quote -1
