    This is some of my works
    193 Posts 26 Posters 40.8k Views 26 Watching
    • orgelfO Offline
      orgelf
      very cool "vehicle for movement on mars" 😄
      http://www.orgelf.com
      • numbthumbN Offline
        numbthumb
        Jerrycans? What fuel does that Mars vehicle use? 😄
        Seriously, interesting concept. Looks like you have paid more attention to curved parts - they look quite segmented on your previous models.
        Comfortably numb...
        • cj_sniperC Offline
          cj_sniper
          in cans no fuel (fuel - nuclear generator) in their water! Something without which it simply can not survive on Mars (and elsewhere)
          http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
          I'm not a magician, I just learn
            cj_sniper
            The rover "TUSHKAN"
            Fuel: in the back of the rover is electric generator at a nuclear fuel, the rotation of the wheels is a chain mechanism with independent motors.
            Type the passengers: the rover descends to a height of 50 cm between the hull and the surface of B, then the door gets up and moves forward allowing access to passengers and the driver to board the transport "A".
            Features: transport has 4 legs (each of which can be operated independently, which allows him to overcome even the steepest mountain surface) radius of the variability of foot 80 degrees "C". Wheels with tires of low pressure for maximum grip with the ground, equipped with spiked steel inserts. Changing the wheels is made in 3 steps: prepare a spare tire and lift the injured leg of transport, unhook the damaged wheel (turning off the hydraulic lock in the mechanism near the wheels), insert a spare tire in the grooves and re-enable the hydraulic clamps (mounting), thereby fixing the wheel. The wheels have ball bearings at the bottom of the foot, which adds increased maneuverability.
            Transportation is also equipped with two 40 liter jerry cans with water (so to speak NC)
            Designed for movement on the surface of Mars during its colonization (or rather for the mountain and crater surfaces), requires the presence of gravity)). Used as a scout the territory.
              numbthumb
              Aaah..water jerrycans. Hope they´re properly insulated 😄
              Very imaginative work!
              Comfortably numb...
                cj_sniper
                thanks
                  chocolate_fou
                  Nice concepts you got there...keep it up..
                    cj_sniper
                    a couple of my works
                    toy cars
                      cj_sniper
                      moonwalker for tourists "crater Turtle"
                      panoramic roof and sides - for better viewing
                        cj_sniper
                        and again retro inspiration
                          cj_sniper
                          walking assault unit "ARAHNIS"
                            cj_sniper
                            buying a PSP myself getting a lot of positive BUT! faced with Massenet inconvenience ... a) for a long game, tired of the big toe (always using analog stick), b) in bright weather should be awkward to hold the console so that no glare on the screen, c) sometimes tries to console slip, D) can be connected only native headset (microphone mean), е) access to the configuration only through the main menu, а) lack of buttons mute (to constantly roll the volume) there is still a few minor flaws...
                            In general, thinking I came up with my own version of the portable console: a) an analog stick instead of a rubber ball (like a mouse had been previously), b) can now monitor range, which helps to avoid glare, while not changing the user-friendly console freeze, c) on the sticking are matte rubber grips for maximum grip with the hand and comfort, d) universal plugs for headsets, e, f) button displayed on the front panel (hold, mute, vol +, vol-, power, home, select, start, britnes, menu, lan, indicators lan, mem and on / off (light bulbs) have been derived under the monitor (they are dim in this do not interfere).
                            In general, next-generation console, running on the mini blu-ray and memory card, batteries are in the arms Console
                              cj_sniper
                              mp3 player for girls
                              • Bryan KB Offline
                                All of your new ones are well done.
                                Hope you find someone to fund you. You have some real winners there.
                                  cj_sniper
                                  Bryan K - thankyou
                                    cj_sniper
                                    inspired by Green Hornet (the movie)
                                    GREEN BEAUTY
                                      cj_sniper
                                      TRON throne chair
                                      Alcantara and leather, LED lights on when getting into a chair, adjustable brightness and illumination color, frame chairs metal plastic. Built-in armrests, programmable remote control of electronics
                                        cj_sniper
                                        futuristic car in 50s
                                          cj_sniper
                                          I have a weakness, I love all transparent ...
                                          and here at leisure pile 2 sets of acrylic furniture
                                          coffee table and 2 chairs (set relax)
                                          Dining table and 4 chairs (dining set)
                                            cj_sniper
                                            Children's chest of drawers
                                            main advantage - no trauma due to the lack of sharp corners + child will be interesting to hide toys in the semi-circular niches on each side of chest
                                            • 9
                                            • 10
                                            • 2 / 10
