    This is some of my works
    193 Posts 26 Posters 40.3k Views 26 Watching
    • cj_sniperC Offline
      cj_sniper
      LED Lamp "Flower Power", the lamp not only change the brightness but also hide behind the petals ... lamp equipped with a clock, alarm and has 3 modes:
      1. Manual (adjust themselves what light you need and enable, disable) manipulations performed by touching the touch-mound at the base of the lamp,
      2. automatic time (ask what time the lamp is switched on and off in what, as well as the intensity of light) button on the left of the clock
      3. Automatic on sensitivity (the base is a light sensor, if the lamp goes dark, the darker the brighter the lamp lights and acc. vice-versa) button on the left of the clock
      http://i1118.photobucket.com/albums/k606/cj_sniper/untitled101.jpg
      http://i1118.photobucket.com/albums/k606/cj_sniper/untitled100.jpg
      http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
      I'm not a magician, I just learn
        cj_sniper
        BLUESKY chopper
        http://i1118.photobucket.com/albums/k606/cj_sniper/untitled34.jpg
        http://i1118.photobucket.com/albums/k606/cj_sniper/untitled35.jpg
          cj_sniper
          Here are a couple of robot (complete sets of furniture, "Hills" was made ​​of 10 pieces, after the crisis ceased to be ordered, as expensive in production)
          Roulette "WilderWestern"(to make when he was the height of the gambling business in Ukraine for a chain of casinos, only 5 tables were produced
          http://i1118.photobucket.com/albums/k606/cj_sniper/untitled118.jpg
          http://i1118.photobucket.com/albums/k606/cj_sniper/untitled119.jpg
          http://i1118.photobucket.com/albums/k606/cj_sniper/untitled120.jpg
            cj_sniper
            LED Park Lamp "Lily"
            completely autonomous because powered by solar elements, the body is made of fiberglass, painted in green color is not obtrusive than it does not emit light from the composition of the park, ceiling made ​​of reinforced plastic, inside a LED elements
            Rod with a metal frame. Lamp height (an element) 3,5 m and 1,1 m. rod removal Destination: lighting fittings, sidewalks, pedestrian zones.
            http://i1118.photobucket.com/albums/k606/cj_sniper/untitled131.jpg
              cj_sniper
              "Jerboa"
              the vehicle for movement on Mars
              • orgelfO Offline
                orgelf
                very cool "vehicle for movement on mars" 😄
                http://www.orgelf.com
                • numbthumbN Offline
                  numbthumb
                  Jerrycans? What fuel does that Mars vehicle use? 😄
                  Seriously, interesting concept. Looks like you have paid more attention to curved parts - they look quite segmented on your previous models.
                  Comfortably numb...
                    cj_sniper
                    in cans no fuel (fuel - nuclear generator) in their water! Something without which it simply can not survive on Mars (and elsewhere)
                      cj_sniper
                      The rover "TUSHKAN"
                      Fuel: in the back of the rover is electric generator at a nuclear fuel, the rotation of the wheels is a chain mechanism with independent motors.
                      Type the passengers: the rover descends to a height of 50 cm between the hull and the surface of B, then the door gets up and moves forward allowing access to passengers and the driver to board the transport "A".
                      Features: transport has 4 legs (each of which can be operated independently, which allows him to overcome even the steepest mountain surface) radius of the variability of foot 80 degrees "C". Wheels with tires of low pressure for maximum grip with the ground, equipped with spiked steel inserts. Changing the wheels is made in 3 steps: prepare a spare tire and lift the injured leg of transport, unhook the damaged wheel (turning off the hydraulic lock in the mechanism near the wheels), insert a spare tire in the grooves and re-enable the hydraulic clamps (mounting), thereby fixing the wheel. The wheels have ball bearings at the bottom of the foot, which adds increased maneuverability.
                      Transportation is also equipped with two 40 liter jerry cans with water (so to speak NC)
                      Designed for movement on the surface of Mars during its colonization (or rather for the mountain and crater surfaces), requires the presence of gravity)). Used as a scout the territory.
                        numbthumb
                        Aaah..water jerrycans. Hope they´re properly insulated 😄
                        Very imaginative work!
                        Comfortably numb...
                          cj_sniper
                          thanks
                            chocolate_fou
                            Nice concepts you got there...keep it up..
                              cj_sniper
                              a couple of my works
                              toy cars
                                cj_sniper
                                moonwalker for tourists "crater Turtle"
                                panoramic roof and sides - for better viewing
                                  cj_sniper
                                  and again retro inspiration
                                    cj_sniper
                                    walking assault unit "ARAHNIS"
                                      cj_sniper
                                      buying a PSP myself getting a lot of positive BUT! faced with Massenet inconvenience ... a) for a long game, tired of the big toe (always using analog stick), b) in bright weather should be awkward to hold the console so that no glare on the screen, c) sometimes tries to console slip, D) can be connected only native headset (microphone mean), е) access to the configuration only through the main menu, а) lack of buttons mute (to constantly roll the volume) there is still a few minor flaws...
                                      In general, thinking I came up with my own version of the portable console: a) an analog stick instead of a rubber ball (like a mouse had been previously), b) can now monitor range, which helps to avoid glare, while not changing the user-friendly console freeze, c) on the sticking are matte rubber grips for maximum grip with the hand and comfort, d) universal plugs for headsets, e, f) button displayed on the front panel (hold, mute, vol +, vol-, power, home, select, start, britnes, menu, lan, indicators lan, mem and on / off (light bulbs) have been derived under the monitor (they are dim in this do not interfere).
                                      In general, next-generation console, running on the mini blu-ray and memory card, batteries are in the arms Console
                                        cj_sniper
                                        mp3 player for girls
                                        • Bryan KB Offline
                                          All of your new ones are well done.
                                          Hope you find someone to fund you. You have some real winners there.
                                            cj_sniper
                                            Bryan K - thankyou
                                            • 2 / 10
