    This is some of my works
    193 Posts 26 Posters 57.5k Views 26 Watching
    • cj_sniperC
      cj_sniper
      "Jerboa"
      the vehicle for movement on Mars
      http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
      I'm not a magician, I just learn
      • orgelfO
        orgelf
        very cool "vehicle for movement on mars" 😄
        http://www.orgelf.com
        • numbthumbN
          numbthumb
          Jerrycans? What fuel does that Mars vehicle use? 😄
          Seriously, interesting concept. Looks like you have paid more attention to curved parts - they look quite segmented on your previous models.
          Comfortably numb...
          • cj_sniperC
            cj_sniper
            in cans no fuel (fuel - nuclear generator) in their water! Something without which it simply can not survive on Mars (and elsewhere)
            • cj_sniperC
              cj_sniper
              The rover "TUSHKAN"
              Fuel: in the back of the rover is electric generator at a nuclear fuel, the rotation of the wheels is a chain mechanism with independent motors.
              Type the passengers: the rover descends to a height of 50 cm between the hull and the surface of B, then the door gets up and moves forward allowing access to passengers and the driver to board the transport "A".
              Features: transport has 4 legs (each of which can be operated independently, which allows him to overcome even the steepest mountain surface) radius of the variability of foot 80 degrees "C". Wheels with tires of low pressure for maximum grip with the ground, equipped with spiked steel inserts. Changing the wheels is made in 3 steps: prepare a spare tire and lift the injured leg of transport, unhook the damaged wheel (turning off the hydraulic lock in the mechanism near the wheels), insert a spare tire in the grooves and re-enable the hydraulic clamps (mounting), thereby fixing the wheel. The wheels have ball bearings at the bottom of the foot, which adds increased maneuverability.
              Transportation is also equipped with two 40 liter jerry cans with water (so to speak NC)
              Designed for movement on the surface of Mars during its colonization (or rather for the mountain and crater surfaces), requires the presence of gravity)). Used as a scout the territory.
              • numbthumbN
                numbthumb
                Aaah..water jerrycans. Hope they´re properly insulated 😄
                Very imaginative work!
                Comfortably numb...
                • cj_sniperC
                  cj_sniper
                  thanks
                  • C
                    chocolate_fou
                    Nice concepts you got there...keep it up..
                    • cj_sniperC
                      cj_sniper
                      a couple of my works
                      toy cars
                      • cj_sniperC
                        cj_sniper
                        moonwalker for tourists "crater Turtle"
                        panoramic roof and sides - for better viewing
                        • cj_sniperC
                          cj_sniper
                          and again retro inspiration
                          • cj_sniperC
                            cj_sniper
                            walking assault unit "ARAHNIS"
                            • cj_sniperC
                              cj_sniper
                              buying a PSP myself getting a lot of positive BUT! faced with Massenet inconvenience ... a) for a long game, tired of the big toe (always using analog stick), b) in bright weather should be awkward to hold the console so that no glare on the screen, c) sometimes tries to console slip, D) can be connected only native headset (microphone mean), е) access to the configuration only through the main menu, а) lack of buttons mute (to constantly roll the volume) there is still a few minor flaws...
                              In general, thinking I came up with my own version of the portable console: a) an analog stick instead of a rubber ball (like a mouse had been previously), b) can now monitor range, which helps to avoid glare, while not changing the user-friendly console freeze, c) on the sticking are matte rubber grips for maximum grip with the hand and comfort, d) universal plugs for headsets, e, f) button displayed on the front panel (hold, mute, vol +, vol-, power, home, select, start, britnes, menu, lan, indicators lan, mem and on / off (light bulbs) have been derived under the monitor (they are dim in this do not interfere).
                              In general, next-generation console, running on the mini blu-ray and memory card, batteries are in the arms Console
                              • cj_sniperC
                                cj_sniper
                                mp3 player for girls
                                • Bryan KB
                                  All of your new ones are well done.
                                  Hope you find someone to fund you. You have some real winners there.
                                  • cj_sniperC
                                    cj_sniper
                                    Bryan K - thankyou
                                    • cj_sniperC
                                      cj_sniper
                                      inspired by Green Hornet (the movie)
                                      GREEN BEAUTY
                                      • cj_sniperC
                                        cj_sniper
                                        TRON throne chair
                                        Alcantara and leather, LED lights on when getting into a chair, adjustable brightness and illumination color, frame chairs metal plastic. Built-in armrests, programmable remote control of electronics
                                        • cj_sniperC
                                          cj_sniper
                                          futuristic car in 50s
                                          • cj_sniperC
                                            cj_sniper
                                            I have a weakness, I love all transparent ...
                                            and here at leisure pile 2 sets of acrylic furniture
                                            coffee table and 2 chairs (set relax)
                                            Dining table and 4 chairs (dining set)
                                            • 2 / 10
