    How to change mesure please ?
    4 Posts 3 Posters 338 Views 3 Watching
    • E
      erzane
      hi,
      I m looking for change mesure definition
      actually I have ''inches''
      I would like to have ''cm'' or ''meter'' if possible
      thanks
      p.s. I went on the menu
      windows >preferences >model types and choose 'meter model' but nothing changed that's why I ask for it
      • soloS
        solo
        Go to window/ model info. change it there.
        See 'Units' on bottom.
        http://www.solos-art.com
        • GaieusG
          Hi Gábor,
          Under Preferences > Templates, you can change what kind of template to open a new SU file with. As far as I know, there is none with centimetres - there are with metres and millimetres though.
          You can open a new file then go to Window > Model info > Units. Here set whatever you like - also you can do other changes in style etc. then go to File > Save as template... At the bottom left, make sure to set it as default.
          Start a new file and your settings should be made now.
          • E
            erzane
            thanks
            done ; )
