    Network rendering
    renderpluginsextensions
    3 Posts 2 Posters 638 Views 2 Watching
      AcesHigh
      When I set to render a scene in a network, I must have the SAME scene open in all computers, right?
      But what about the materials? Must I copy the scene + all used materials to every computer too?
      • broomstickB Offline
        broomstick
        No that is not necessary, what you need is to activate the drspawner on the target machine, before rendering on the main machine. You need to tell the main machine where the other pcs are on the network, and finally you need to make sure the folder where your model and vray materials are, is shared with all the other machines.
        I hope this helps
          AcesHigh
          "you need to make sure the folder where your model and vray materials are, is shared with all the other machines"
          thanks, thats actually very important to know... (I never bothered to check it before)
