    Opaque Images Appear Transparent
    3 Posts 3 Posters 789 Views 3 Watching
      dsacher87
      Any idea what caused the problem shown in the attached image? I never was able to fix it, but did manage to find a work around. I restarted the program, and the computer with no effect. I changed 'hardware acceleration' and 'fast feedback' which didn't help, and I opened the file on another computer. What did work (at least it seems to now), was to copy and paste all of the objects in this file into a completely new file. Help would be appreciated!
      -Dave
      Note how you can kind of see through everything.
        Hi Dave,
        It seems that Back Edges (something new in SU 😎 are set active in your current style. Uncheck them under Window > Style > In model... (and do not forget to refresh your style).
        If this is in your default template (i.e. it starts with this setting all the time), do the changes in an empty file and save it as a template under the File menu (don't forget to set it to your default template at the bottom checkbox)
          Builder Boy
          OR... you could just hit the "K" key (if you haven't changed that)
          All my plugins
