    Licence & new versions of sketchup
    3 Posts 3 Posters 501 Views 3 Watching
      davesec
      hi!
      my work has a copy of sketchup pro on one of our machines, version 7.1 i think, single-user licence. does anyone know if i download a later version of sketchup, it'll cost more, or i'll have to update my licence, or do anything, really? i don't want to screw up this machine, but if i can be sure that i simply click 'update version' or whatever, it'll do it automatically and i won't have to re-configure anything
      thanks!
        You can install V8, either pro or free along side 7.1. They are separate installations so you won't wreck the exisint version with the new version.
        There is a cost for buying version 8 pro but it is less than $100 US.
        If you install 8 pro and use up the 8 hour eval time, it will revert to the free version.
          There are some cool, new features of SU 8 Pro (like solid tools and a bunch of improvements in LO for instance) so if you want to try them, I suggest installing it. Do not touch SU 7. Just download SU 8 (Pro if you want to try) and install it side by side version 7. I have 6, 7 and 8 installed (and use them all occasionally). You can even run two, different versions at the same time.
          Then if you like 8 Pro, you can upgrade - and yes, I also think it's about $ 95.
