    Very difficult key codes!
    10 Posts 4 Posters 948 Views 4 Watching
      macgile
      hello all
      First sorry for my poor English:)
      three days since I am fighting with the shortcut.
      I want to delete the paths in the plugin camerakeymaker with the shortcut ALT + DELETE
      In the MAC OSX (ALT + DELETE) it's available only on onKeyUp and work fine
      on the PC it's available on the onkeyDow AND onkeyup.
      But in the pc it does not work correctly on onkeyup
      onkeyup;
              if ((key == VK_DELETE) && ((flags & VK_ALT) == VK_ALT))
               p "OnKeyDown; DELETE PATH"
      When I press (alt + delete) or (delete only) it pass in statement
      do you can help me ???
      best regard
      • Dan RathbunD Offline
        Dan Rathbun
        (http://forums.sketchucation.com/viewtopic.php?f)":dwixdyu1]
        I haven't been able to trigger a VK_ALT on either system.
        I'm not here much anymore.
          I was never able to catch VK_DELETE under Windows...
            Dan Rathbun
            I would say that straightforward simplicity is the lowest form of elegance. 😄
              Here is what I find, under Windows:
              When only Delete is pressed, it triggers only onKeyUp.
              When Shift+ Delete is pressed, it only onKeyUp.
              When Ctrl+ Delete is pressed, it triggers both onKeyDown and onKeyUp.
              When Alt+ Delete is pressed, it triggers both onKeyDown and onKeyUp.
                macgile
                Thank's thomthom
                thank you it is very useful 😄🙂
                  macgile
                  oups
                  fix for mac :
                  K_CTRL_ALT = VK_CONTROL.to_s << VK_ALT.to_s
                  K_ALT_DEL = VK_ALT.to_s << VK_DELETE.to_s
                  onKeyUp
                  #window || mac (on mac, delete it triggers only in onKeyUp)
                  if(@flags == K_ALT_DEL || (@flags + key.to_s) == K_ALT_DEL))
                  do something
                    macgile
                    hi Dan Rathbun,
                    first thank's to reply 😄
                    i have found this solution
                    windows :
                    K_CTRL_ALT = COPY_MODIFIER_KEY.to_s << ALT_MODIFIER_KEY.to_s
                    K_ALT_DEL = ALT_MODIFIER_KEY.to_s << VK_DELETE.to_s
                    mac:
                    @flags =""
                    CTRL + ALT or ALT + DEL
                    def onKeyDown(key, repeat, flags, view)
                    SAVE KEY to string
                    @flags += key.to_s
                    def onKeyUp(key, repeat, flags, view)
                    if (@flags == K_CTRL_ALT)
                    do something
                    #window or mac (on mac, delete it triggers only in onKeyUp)
                    do something
                    @flags = ""
                    it's not "très élégant" but it works with any key combination
                    best regard
                      I'm unable to access my mac atm. Anyone able to run this on Mac and check the results? I'm curious if VK_DELETE register on key down under OSX.
                        Also note that TAB on MAC only fires with onKeyUp and is ignored otherwise !
                        The TAB key == 9 or 15 or 48 [for PC or MAC or ??]
