    Problem with faceted renders using Twilight and Artisan
    3 Posts 3 Posters 501 Views 3 Watching
    • W Offline
      Whaat
      I received a support email from someone evaluating Artisan and he said that since installing Artisan, everything renders faceted in Twilight whether edges are set to smooth or not. Has anyone else experienced this?
      Thanks,
      Dale
      • FrederikF Offline
        Frederik
        Tell the user to...
        If it's already grouped, then explode the group and then re-group it and everything will look smooth... πŸ˜‰
        If it's not grouped, then just group and hit render... πŸ˜„
        You can check this thread: http://www.twilightrender.com/phpBB3/viewtopic.php?p=12044#p12044
        (Wonder why you've posted this question here and not at the TWR Forum...??)
        Cheers
        Kim Frederik
        • W Offline
          wozabee
          HOOLLLD EV'RYTHING!!!
          After nuch banging-of-head-on-desk... and experiments... I tried Frederik's suggestion. No dice. But did the same and made into a COMPONENT... all solved! ...for now. Though I'm still fuzzy as to why this should actually work. But. Don't question miracles (well, not DIGITAL ones, anyway).
          Busy now doing jolly fantastic things with it.
          I is now in heaven!
          I think by FAR the Artisan will turn out to be the best thing to happen to sketchup to date.
          Cheers all,
          Woz
