    Large Terrain Mesh
    105 Posts 11 Posters 24.3k Views 11 Watching
    • B
      bjornkn
      @dbwv69 said:
      While the primary purpose of the terrain will be to display various scenes from the area, it will also be used to show mining and other activity which requires that some level of detail remain in tact. The mountains do not have to have much detail, other than the general shape, but the lower elevations absolutely must have crisp boundaries because of the proximity of homes, roads, streams, and railroad lines, all tightly packed in among the mountains. You would have to see the area up close to understand fully because satellite images just don't do it justice.
      Drawing an area of this size by hand is not a task that I would want to even contemplate doing. Especially with the terrain involved.
      Do you really have any choice? Even though DE may do a good job reducing the mes it will not add any detail where there is none. Neither will it use different rules in selected areas (my version doesn't anyway).
      Have you actually tried the GP/Triangulate method? It is actually quite fast, and allows you to add detail exactly where you need it, and it allows you to add some edges/creases where there are only ssoft dunes in the dxf mesh.
      Like on this little 100 faces patch elevated 50cm to make it visible entirely above the ground. 5mins?Clipboard-4.jpg
      • soloS
        solo
        Vue9 can import the dxf, dem, ect, then assign material based on slope, height, orientations or even selected with paint brush tool.
        Here is a very fast example.
        http://www.solos-art.com
        • D
          dbwv69
          What is GP?
          • D
            dbwv69
            I'm a bit confused... So you used Vue to do the reduction shown earlier? I thought you had used Deep Exploration but when I tried a 90% reduction, it it didn't look very good.
            • soloS
              solo
              The earlier one was Deep exploration, the above was Vue, I simply imported the dxf and painted terrain by elevation. No need to reduce as Vue can handle billions of poly's without glitch. However I can reduce in Vue and export to SU if needed.
              • D
                dbwv69
                I have Deep Exploration and have tried to replicate the reduction results you achieved earlier but without success. Can you tell me how you did it?
                • soloS
                  solo
                  Sure.
                  Open dxf in SU, then save as SU6 version.
                  Open it up in DE, and select reduce, process and select 90 percent. Then select heal and save as SU model.
                  That's all.
                  • D
                    dbwv69
                    @solo said:
                    Sure.
                    That's all.
                    Oh, I see. So you were only removing 10% of the triangles. No wonder I was having issues, I was clicking 10%, thus removing 90% of the triangles.
                    • soloS
                      solo
                      No, remove 90 percent. see file size from 35MB to 2.6MB
                      see image:
                      • D
                        dbwv69
                        see image:
                        Then there is hope for it still. I am doing the same, or so I thought, but the results are not like yours. I wonder what it could be? My version comes out with strange patches or blotches all over it..
                        • M
                          mac1
                          Other filtering approaches using MeshLab again but this time doing Vertex Clustering Decimation. SU edges 25625,16900 faces and file size 2599K. The filters it includes are some developers have incorporated in their apps. .Vertex Clustering Decimation.jpg[/attachment]
                          IMO trying to take this model and editing is not the way to go based on the goal of your OP. To create a virtual tour you must get to the point of selective editing only portions of the map along the lines bjornkn discusses This can be in the decimation or interpolation sense ❓
                          Next step, layers and selective edits?
                          • D
                            dbwv69
                            Those results look quite promising and seem to retain much of the fine detail.
                            I completely agree about only editing certain portions along the line. Given the sample I uploaded, a true sense of perspective is lost. Here is a set of 3 meter contours for the entire area involved. I would upload the full resolution version but the file size exceeds the attachment limits. The small patch I uploaded is located near the lower portion of the midpoint. See attachment:
                            Full Area Contours.zip
                            • soloS
                              solo
                              Got that in a DEM file? or even .obj, dxf.
                              • D
                                dbwv69
                                Yes. I am actually using a DEM file as the source for the sample DXF I uploaded.
                                • soloS
                                  solo
                                  If you can upload it, or part of it, I'd like to try something with Terragen.
                                  • D
                                    dbwv69
                                    I tried uploading it earlier and it was rejected because the file was too large.
                                    • soloS
                                      solo
                                      Got a dropbox account? they are free, safe and private.
                                      • D
                                        dbwv69
                                        No but I can get one. Where do you reccommend?
                                        • soloS
                                          solo
                                          Install Dropbox for Windows and Mac
                                          Dropbox helps you create, share, and collaborate on your files, folders, and documents. Learn how to download and install Dropbox for Windows and Mac.
                                          (www.dropbox.com)
                                          • D
                                            dbwv69
                                            (www.dropbox.com)
                                            I'll go create an account now. What format do you prefer the data to be in? I am currently extracting it to a DXF mesh, is that ok?
                                            • 6
                                            • 3 / 6
