    Group.volume
    11 Posts 5 Posters 751 Views 5 Watching
      morci429
      Guys did anyone try using group.volume function?? i've been trying to use it but it doesn't seem to work. any body came across the same thing before??
      • Dan RathbunD Offline
        Dan Rathbun
        ](http://code.google.com/apis/sketchup/docs/ourdoc/group.html#volume)":3osf11lz]
        Sketchup 8.0+
        The volume method is used to compute the volume of this group if and only if this group is manifold.
        ... If the group represents a manifold volume, volume will be a positive value. If volume is negative, the group is not manifold.
        See Also: Group.manifold?
        I'm not here much anymore.
          Dan Rathbun
          Mike, are you using Free or Pro edition ?
          Can you provide an example of when it "doesn't work" ?
          • Didier BurD Offline
            Didier Bur
            If you're in trouble with group.volume, try this: (assumed g parameter is a group entity)
            def vol(g)
            	v=0.0
            	for face in g.entities
            		next unless face.kind_of? Sketchup;;Face
            		v +=(2*face.area*face.vertices[rand(2).to_i].position.to_a.dot(face.normal))/6
            	# if needed, convert cubic Inches to m3
            	return (v * 0.000016387064)
            DB
              morci429
              Hi Didier, Great code thank u very much it did the job for me but its always worth to learn another way so Dan here's what i was trying to do with group.volume
              pt = []
              pt[0] = [0,0,0];pt[1] = [100,0,0];pt[2] = [100,100,0];pt[3] = [0,100,0]
              face = Sketchup.active_model.entities.add_face pt
              face.pushpull -100
              then i had to find out how many entities i had in the model and which of them is faces so i can add them to the group using selection.clear and selection.add
              and then i add all the faces to a group and i made a few copies of it.
              and i tried to use the function but it never worked.
              could you demonstrate a good practice of the function?
              thanks you πŸ˜„
                Why not add the face directly into the group in the first place?
                model=Sketchup.active_model
                group=model.active_entities.add_group()
                face=group.entities.add_face(pt)
                face.pushpull(-100)
                faces=[]
                group.entities.each{|e|faces << e if e.class==Sketchup;;Face}
                now faces is an array of all of the new faces inside group ?
                You can use new_group=group.copy etc...
                Then
                new_faces=[]
                new_group.entities.each{|e|new_faces << e if e.class==Sketchup;;Face}
                etc etc...
                  morci429
                  that is certainly a better way thank you.
                  but still group.volume still not working.
                  did you use it before? what would be the way to use it?
                  thanks
                    The group.volume in v8 [ http://code.google.com/apis/sketchup/docs/ourdoc/group.html#volume ] and Didier's way otherwise should both work... for 'manifold' / 'solid' forms...
                    What is the output/error in the Ruby Console ?
                      Exactly what isn't working?
                      Unexpected result?
                      Errors?
                        morci429
                        Didier's way is working with no proplems.
                        and this is the error message when i try to use group.volume
                        group.volume
                        Error: #<NoMethodError: (eval):41: undefined method `volume' for #Sketchup::Group:0x4d28ba0>
                        (eval):41
                          morci429
                          i think i know where the problem is.. it only works in SketchUp 8. i just tried it
                          really sorry about that.
                          i was using 7 before that
