    Empty Triangles
    7 Posts 3 Posters 433 Views 3 Watching
      bupaje
      I was trying to create candles and I see some empty triangles. Is there any easy way to fix these? I was zooming way in with hidden lines and trying but seems difficult. Wasn't sure if I should post a file or this is a common problem.
      http://stormvisions.com/media/sketchup/candle.jpg
      Burt
      Stormvisions
        d12dozr
        If the geometry is small (lines less than ~1mm), SU has trouble making faces. Try scaling up by 10 or 100X while making the geometry, then scaling back down when finished.
        http://goo.gl/f7ooYh
          bupaje
          Thanks for that will try - though now I am not 100% sure the triangles are missing. I had a material set too 95% opacity. When I set it to 100% the triangles go away. Will take scale and check as you suggest.
          Burt
          Stormvisions
            d12dozr
            Maybe there are overlapping faces then...if you post the file I'll take a look.
              bupaje
              As I copied the candle by itself into a new file I found the problem. I had tested a translucent material before this. Somehow some faces seemed to retain this material. I noticed that there were two materials in the wax candle even though should only have been one. When I deleted it gave me the "Materal is in use - Are you sure?" message and deleting it removed those phantom triangles.
              Thanks for pushing me in the right direction. πŸ˜„
              candle.skp
              Burt
              Stormvisions
              • jeff hammondJ Offline
                jeff hammond
                yeah, the faces are there.. it's the material transparency that's causing the problem (well, actually it's a setting in your styles that's causing the problem)
                (the following instructions are for macs so the paths may not be exact)
                go window->styles ->click on the edit button -> face settings button ..
                in the transparency quality drop down, select nicer instead of faster.
                dotdotdot
                  bupaje
                  Thanks very much!
                  Burt
                  Stormvisions
