    Green newbie,plugin problem
    5 Posts 2 Posters 303 Views 2 Watching
      coastman
      Hi there,
      Im a very green newbie here but making good progress with sketchup(Heaps of fun).I thought I would be smart and download Roundcorner,after an hour or so I found the plugin folder thingy(I aint a commputer geek!!!)But cant get the program from there into sketchup.I know Ive either done something wrong or havent done something that I shouldve.
      Sorry if its hard to understand but unsure of the commputer terminolgy(sp)cant even spell 😲
      Thanks for reading anyway.
      Must say theres a hell of alot of very clever people on this forum,glad I stumbled on it.
      Cheers
      Stu
        Hi Stuart and welcome4
        Did you also install that additional, necessary library "libfredo"?
        http://forums.sketchucation.com/viewtopic.php?f=323&t=17947#p144178
        Also, you need to activate the plugin under Window > Preferences > Extensions. Then you will have a toolbar under View Toolbars.
        If it still does not work (you need to restart SU after installation and also after activation), make a screenshot of your plugin folder and post here (attach a file under the text area you are posting)
          coastman
          Hi Caieus
          thanks for fast reply.Have done what you said and no i hadnt down loaded the libary.Still cant get it to work.the " Libfredo" is in the list under window.
          Just to show how uncommputerized I am,how do you save ascreenshot of my plugin window??
          I can hear you sighing from here!!
          Cheers
          Stu
            Well, your plugin library should look something like this:
            http://forums.sketchucation.com/download/file.php?id=61807
            I use Gadwin Print screen to take screenshots (it has a free version, too):
            http://www.gadwin.com/printscreen/
              coastman
              With your help mate I have done it 😍 And it works great.
              Thanks for the pionters Caieus couldnt have done it without ya.
              Just a warning.....Ill probably be back soon with another problem!!!
              cheers
              Stu.
