    Can You Draw Lines on a Curve Surface?
    5 Posts 3 Posters 8.8k Views 3 Watching
    • C
      cmartin
      Is there a way to draw lines on curved surfaces? I know you can goto view | show hidden geometry and then select window | soften edges and make those lines available, but sometimes hidden geometry doesn't have the all the lines I need.
        Tools on surface by Fredo6 πŸ˜‰
        • StilTegS
          StilTeg
          without plug-in, you may also draw a plane and intersect it to your surface ...
          doing technical engineering on SketchUp ... without plugins
          • C
            cmartin
            I'm sorry, I meant draw curved lines on curve surfaces that match the curve.
              Curves don't exist inside Sketchup, that is only small straight lines or small flat surfaces! πŸ˜‰
              So the Tools on Surface of Fredo6 is perfect for that πŸ˜‰
              Your "false" real curve will be match your false "real" curvated surface πŸ˜‰
              That is not a nurbs modeler! If you want real curves and real curvated surfaces
              you must have for example a Nurbs modeler in the spirite of ergonomy of Sketchup β˜€
              Try Moment of Inspiration : Moi 😎
              It's a true gem! 😎
              You have an infine demo for training πŸ˜‰
