Can You Draw Lines on a Curve Surface?
Is there a way to draw lines on curved surfaces? I know you can goto view | show hidden geometry and then select window | soften edges and make those lines available, but sometimes hidden geometry doesn't have the all the lines I need.
Tools on surface by Fredo6
without plug-in, you may also draw a plane and intersect it to your surface ...
I'm sorry, I meant draw curved lines on curve surfaces that match the curve.
Curves don't exist inside Sketchup, that is only small straight lines or small flat surfaces!
So the Tools on Surface of Fredo6 is perfect for that
Your "false" real curve will be match your false "real" curvated surface
That is not a nurbs modeler! If you want real curves and real curvated surfaces
you must have for example a Nurbs modeler in the spirite of ergonomy of Sketchup
Try Moment of Inspiration : Moi
It's a true gem!
You have an infine demo for training
