    Sort of road plugin
    7 Posts 5 Posters 1.0k Views 5 Watching
      miikka1978
      Is the a plugin that could be used for making roads/paths on a planar surface? Basically, I am doing now:
      • Draw centerline with Catmul Sline- plugin
      • Offset that twice
      • Close the ends with lines
      • Delete the centerline
      I will need to do that about 50-70 times, so it would be much faster with some kind of plugin. I would assume that this plugin is already available but I can't just think any Plugin that would perform this function.
        SketchUpNoobie
        Have you seen this plugin? It's not free but it looks very useful. And it's relatively cheap.
        Edit: Marcus beat me. 😑
        SketchUpNoobie: the complete noob in all things SketchUp.
          d12dozr
          I think this does what you want:
          404 Not Found
          (www.valiarchitects.com)
          http://goo.gl/f7ooYh
            miikka1978
            Thanks for the ideas! This plugin looks amazing and I will probably use it when making roads on terrain. Anyway, this time I was looking something really simple and quick because I just need to trace the roads on a picture. If you happen to know something that could be used for this "double offset and close the lines function", please let me know.
            • fredo6F Offline
              fredo6
              There is also the Street Generator by Thomthom.
              Fredo
                miikka1978
                Fredo
                Thanks, this absolutely something that I need to take a look about!
                  you have also this πŸ˜‰
                  Shape Bender by Chris Fullmer
                  Second part of the video can interest you πŸ˜‰
                  [flash=480,390:13h1j78f]http://www.youtube.com/v/tGHTIOMm_34?fs=1[/flash:13h1j78f]
