    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [REQ] Scale Definition
    6 Posts 3 Posters 2.2k Views 3 Watching
    • PixeroP Offline
      Pixero
      Is there a plugin that iterates through the selection and makes each group a component and then scales it's definition?
      (I have some imported Revit geometry that causes problems.)
      Edit: If it's a component already it would just scale the definition.
        tr=Geom;;Transformation.scaling(ORIGIN,10,10,10);Sketchup.active_model.selection.to_a.each{|e|next if e.class!=Sketchup;;Group;n=e.name;n='G'if n=='';i=e.to_component;i.name=n;d=i.definition;d.name=n;d.entities.transform_entities(tr,d.entities.to_a)}
        This makes every selected group into a component [named after the group, or G/G#1/etc if it's unnamed], with the same name, and scales the definition x10 about it's insertion point [ORIGIN] - change those values to suit yourself...
        EDIT: for a component use this
        tr=Geom;;Transformation.scaling(ORIGIN,10,10,10);Sketchup.active_model.selection.to_a.each{|e|next if e.class!=Sketchup;;ComponentInstance;d=e.definition;d.entities.transform_entities(tr,d.entities.to_a)}
        • PixeroP Offline
          Pixero
          I meant "Scale Definition" as in right clicking a component and selecting it from the pop up menu. No idea what scale number to use. One?
            Aha...
            You mean scale the definition to match the current instance's scale ?
            In that case it's a bit more complicated and simpler at the same time! ...
            If it's a scaled group it will convert to a component instance at its current scaling - but the definition will be the original size. The quick fix is to clone the group inside a new group of the same name, and erase the original group, then explode the clone within the new group so its scaling gets 'frozen', THEN make that group into a component that is no longer scaled and the current size instead
            m=Sketchup.active_model;m.start_operation('X');m.selection.to_a.each{|e|next if e.class!=Sketchup;;Group;n=e.name;n='G'if n=='';g=m.active_entities.add_group;t=g.entities.add_instance(e.entities.parent,e.transformation);e.erase!;t.explode;i=g.to_component;i.name=n;d=i.definition;d.name=n};m.commit_operation
            If it's already an instance we can use
            m=Sketchup.active_model;m.start_operation('X');m.selection.to_a.each{|e|next if e.class!=Sketchup;;ComponentInstance;d=e.definition;n=e.name;g=m.active_entities.add_group;t=g.entities.add_instance(d,e.transformation);e.erase!;t.explode;i=g.to_component;dd=i.definition;d.instances.each{|ii|ii.definition=dd};d.name=n+rand.to_s;dd.name=n;d.entities.erase_entities(d.entities.to_a)};m.commit_operation
            This makes all instances of a definition the same ? Do you only get one of each from Revit ??
            • PixeroP Offline
              Pixero
              Thanks, this seemed to work. ๐Ÿ‘
              The problem was that the groups was in some huge scale so "opening" a group would cause clipping to go haywire and also textures had to be enormous in scale.
                DOD3R
                I would appreciate an option to scale all components definition to their current scale.
                Is there some plugin for that or any other way of doing it component by component ?
                I have problems with large dwg imports after I scale the to desired size. Formal dwg block imported to sketchup as components are all scaled and I need to manually scale their definitions witch can by labor-some.
