    Faster Delete Materials
    5 Posts 4 Posters 1.6k Views 4 Watching
    • brodieB Offline
      brodie
      Why is it that when you've got a model with say, 25 materials, right-clicking a material to delete it from the Materials panel takes like 30 seconds before the menu pops up to let you delete it?
      -Brodie
      • dereiD Offline
        derei
        similar in this topic http://forums.sketchucation.com/viewtopic.php?f=11&t=33401 no solution yet.
        DESIGNER AND ARTIST DEREI.UK
        • Alan FraserA Offline
          Alan Fraser
          Yes, seems to be a recent thing...and the bigger the model, the longer it takes. It's way shorter using ThomThom's cleanup script.
          3D Figures
            @alan fraser said:
            Yes, seems to be a recent thing....
            I've seen this behaviour since SU6.
            However, my models are much larger now, with better hardware, compared to when I started - with SU6. So the effect is more noticeable.
            • brodieB Offline
              brodie
              Actually this has been around for as long as I can remember. And while I use thomthom's cleanup script and purge all the time, this is still a big issue because sometimes you want to forcefully delete a material that is still in your scene. This happens a lot when you bring in some 3d elements and such and end up with a few oddball materials that you don't want, but don't want to dig around and find out where they are in the model.
              -Brodie
