    Contents Menu to other menu locations
    10 Posts 4 Posters 795 Views 4 Watching
    • kenK
      ken
      Question is it possible to move any or all context menu plugins to another menu, i.e. Tools or Edit? Seems I am getting to many context menu items and I would like to move some of the plugins to either tools or edit. Are context menu plugins stuck in the context menu selection?
      Ken
      • GaieusG
        I guess it would be possible. The code where a menu item should appear is generally somewhere at the end of the scripts (AFAIK).
        Not that I could (probably) modify one successfully... πŸ˜’
        • TIGT
          Yes.
          BUT you need to rewrite the context-menu code...
          For example [made up!]...
          UI.add_context_menu_handler do |menu|
            menu.add_item("Edges from Guide Lines"){xLine2Line()}
          would become something like
          UI.menu("Plugins").add_item("Edges from Guide Lines"){xLine2Line()}
          • kenK
            ken
            Thanks TIG
            Now what I want to know is how did you guess the line_converter.rb is the very plugin that I wish to change.
            And another question, is there any reason beyond just making it easy to select something and have a context menu pop up, or are there programing restraints that require the context menu.
            I would prefer that no other context menu be written since Sketchup seems to have trouble handling these plugins.
            Again thank you TIG
            Ken
            • TIGT
              Thanks TIG
              Again thank you TIG
              Ken
              The code that sets the menu is usually at the end of the script [some, like thomthom are perverse and put it at the start!] Do a 'find' on the script's text for 'menu' or 'context'... that's the code you need to adjust...
              Context menus that are properly st up work fine - they only appear when a specific set of circumstances coincide - e.g. SectionCutFace only appears in the context-menu when you have a one item selection containing a SectionPlane... Sometimes context-menus are used when they are NOT necessary... πŸ˜’
              • kenK
                ken
                I my studies of Ruby for Sketchup, I have no problem with finding the context menu, it just seems to me there is always an "if then" statement, proceeding the menu add statement, and I don't see on this the other menus. There are some plugins that appear in more than one menu, and I usually turn off the context menu, and move the plugin to an other memu selection where I wish to have the plugin appear. However, I have not been able to master the coding to get rid of just a context menu with the "if selection is.....".
                Anyway, I will keep trying.
                Thank
                Ken
                • TIGT
                  Thank
                  Ken
                  The code pseudo-code...
                  if this is not loaded then load it [i.e. make menu items etc] end Now it's loaded
                  code is there to ensure the menu only loads once even if the script is re-loaded...
                  • kenK
                    ken
                    If was more of this type of code. Note, I have tried to remove context menu and add this to the Tools menu. So far, haven't had it to work. However, I am still working on it. What I was wondering, if the two line are required to make sure I that I have picked either a line or xline. Still working on it.
                    if( not file_loaded?("xLine.rb") )
                    if xLine_validate_selection [b]###THIS LINE RIGHT HERE[/b]
                    menu.add_separator
                    menu.add_item("Convert lines to guide lines") { xLine }
                    if line_validate_selection [b]### AND THIS LINE[/b]
                    menu.add_separator
                    menu.add_item("Convert guide lines to lines") { xLine2Line }
                    • TIGT
                      The file_loaded part checks if the file was already loaded,
                      The if xLine_validate_selection part is a check to see if the selection includes suitable entities.
                      If you put a # in front of the 'if' and also in front of its final 'end' then that check is disabled.
                      Alternatively, add a line into the def xLine_validate_selection to return true always...
                      SO on the line immediately after the 'if' line add return true and then the rest of the checking code is ignored anyway....
                      • K
                        kyyu
                        Thank
                        Ken
                        You could write a intermediate method to do the check. If ok, it runs the plugin. If not valid, then it pop up an error message:
                        def xLine_check_valid
                        		xLine
                        	else
                        		UI.messagebox "Invalid selection"
                        	UI.menu("Plugins").add_item("Convert lines to guide lines"){xLine_check_valid}
                        file_loaded("xLine.rb")
