    2D Plan appears warped!
    2 Posts 2 Posters 240 Views 2 Watching
      davidlyman1
      I've run into this before, but am in serious need of help now!
      I've drawn my floor plan in outline only so far, but it's showing triangular 'shadowing' all over. I drew it using Top View, with perspective turned off.
      I'm ultimately going to draw the complete plan to use as part of a Layout presentation- but it's got to start out truly "flat!"
      Why does this happen? I've got to understand this quickly.
      Thanks so much for help...
      David
        It would help if you could post at the very least a screen shot. Better, the SKP file.
        Without seeing it, I'm guessing you are seeing what is referred to as Z-fighting in which two faces occupy the same place in space and the graphics card is trying to resolve which one to show. In a case like that, you probably don't have any problem with co-planarity of lines.
