    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 149.4k Views 46 Watching
      db11
      Hi Fredo β€”
      I'm having a problem with the plugin under SU Pro 2015: It works fine in 2018, but now doesn't work properly in 2015.
      Specifically, I can't pull up the configuration window, either from the menu or by clicking the toolbar button.
      Everything worked fine in 2015 up until either my installation of 2018, or the last SUClock update (both were around the same time).
      Any thoughts on what's going on and how to fix it? Love the plugin and depend on it for my project time-tracking.
      Thanks.
      • fredo6F Offline
        fredo6
        Difficult for me to tell, as I don't have a Mac.
        At least I could test that it works fine on Windows and SU2015.
        Can you open the Ruby console before you launch SUClock and check if there are error messages.
        Fredo
          db11
          I did as you asked, and no error message on the Ruby console. The window flashes open when I hit the toolbar button, but disappears immediately after. (it's visible for a fraction of a second)
          • fredo6F Offline
            fredo6
            Could you make sure you use the latest version of LibFredo6 (v8.7f), as I fixed some bugs related to dialog boxes on Mac.
              db11
              Just updated and it seems to have done the trick. Thanks!
              • fredo6F Offline
                fredo6
                The problem was there for other dialog boxes on Mac. As a general advice, it is always good to update to latest versions of LibFredo6, because this library holds a lot of common code used across all my plugins.
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: SUClock - v1.9c - 12 Nov 17
                  SUClock 1.9c fixes a bug for the CSV export in non-English languages.
                  See SUClock plugin home page for Download.
                  See also main post of this thread for User Discussion.
                  Fredo
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: SUClock - v3.0a - 19 May 20
                    SUClock 3.0a fixes a major bug for display of the clock window.
                    Note also that, from v3.0a onward, SUClock is only supported for SU2017 and above.
                    • E Offline
                      Ehay
                      This post is deleted!
                      • fredo6F Offline
                        fredo6
                        @ehay said:
                        when a version for 2021 will be released?
                        SUClock should work for SU2021.
                          SU Clock does indeed work in SketchUp 2021 as it is.
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE: SUClock - v3.1a - 02 Apr 24
                            Requirements
                            • LibFredo6: v14.3a or above
                            SUClock 3.1a is a maintenance release for:
                            • Future compatibility
                              sstephanoff
                              Question - Is there a way to change the start time. Like I started a project 7 hours ago and forgot to start my clock. Is there a way to adjust the clock?
                              • fredo6F Offline
                                fredo6
                                No. Actually, the time is split between the various tools and activities.
                                I'll see if I can add the feature.
                                E 1 Reply Last reply Reply Quote 1
                                • E Offline
                                  Ehay
                                  Why can't I figure out how to add the SUClock Icon to my toolbar? Am I a dork?
                                  I have Fredo6 LibFredo6 installed as well as Fredo6_SUClock, yet I can't figure out how to get the clock icon on the toolbar.
                                  Cheers!
                                  • fredo6F Offline
                                    fredo6
                                    If you have FredoTools installed, the SUCLock icon is at the end of the FredoTools toolbar.
                                    • E Offline
                                      Ehay @fredo6
                                      @fredo6 that's what I was missing. Thank you!
                                      • K Offline
                                        Kmylpenter Newcomers
                                        Would be great to add a setting allowing to auto open SU Configuration settings at the start of a new Sketchup project.
                                        This way we could make sure we don't forget to turn the timer on. The plugin is great, thank you.
                                        • 6
                                        • 7
                                        • 7 / 7
