    Transformation Newbie...
    4 Posts 3 Posters 494 Views 3 Watching
      tday
      Martin says this is the best newbie forum on Earth!
      http://www.martinrinehart.com/models/tutorial/tutorial_toc.html
      Although I can't consider myself a complete newbie - transformations make me feel that way:
      I'm trying to add a face entity to an existing group nested within a
      component instance. The model structure looks like this:
      model > dynamic component instance > group
      I'm trying to add a new face to the nested group through Ruby. There
      is no edit context when the ruby tool is initialized.
      the code:
      #@ip2,@ip3,@ip4 are input points defining three corners of the
      rectangular face
      #@ptCalculated is the fourth computed corner of the rectangular
      face
      #@spacegroupdef is the existing group inside a DC instance
      #put the rectangle in a group temporarily so the face and 4 edges
      can be transformed as a unit
      bumpgroup = @spacegroupdef.entities.add_group
      bumpgroup.name = "temp bumpgroup"
      #insert the new face
      face1 =
      bumpgroup.entities.add_face(@ip2.position,@ip3.position,@ip4.position,@ptCalculated)
      trans_array = Array.[](1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,1)
      #first, rotate - no rotation required
      #second, scale
      trans_array[0]= trans_spacegroup.inverse.to_a()[0]
      trans_array[5]= trans_spacegroup.inverse.to_a()[5]
      #If the transform! is conducted at this time, the scaling is
      correct
      #I'm sure the input point comes from within the existing face that
      is in the nested group
      trans_array[12] = -(@ip2_transformation.to_a()[12]) #Xt
      trans_array[13] = -(@ip2_transformation.to_a()[13]) #Yt
      new_transform_2 = Geom::Transformation.new(trans_array)
      bumpgroup.transform! new_transform_2
      The translation executes but it is not correct.
      I have tried using two separate transformations in different orders.
      First scale, then translate as above with the same result.
      Also first translate, then scale. In this case the translate works,
      but after applying the scale I get incorrect results.
      Not sure where I am going wrong. Any ideas about what I need to do to
      get the X and Y translation correct?
      Kind thanks!
        You are picking the points in the model.
        The group has a transformation within the component-definition
        The component-instance has a transformation within the model.
        You have four points.
        Make a transformation that uses the instance and group transformations [inverse] and apply that to the points [got from the ip's or calculated]
        Then add the face to the group from the transformed points...
        p2=@ip2.position
        p3=@ip3.position
        p4=@ip4.position
        p5=@ptCalculated
        tr=@spacegroupdef.transformation.inverse * spacegroup.transformation.inverse
        [p2,p3,p4,p5].each{|p|p.transform!(tr)}
        bumpgroup.entities.add_face(p2,p3,p4,p5)
        I haven't tested this but you need to somehow apply the containers' transformations backwards onto the face's points...
          tday
          Thank you TIG,
          I understand the concept - and will let you know how it goes.
          T
            InputPoint.transformation
            http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/inputpoint.html#transformation
            Gives you the transformation for the input point. Will probably be useful to you for converting between local and model co-ordinates.
