    Transpose curved face into an object ?
    5 Posts 4 Posters 447 Views 4 Watching
      sswcharlie
      Not sure if I have the description right. Anyway I have managed to make a curved skirt as per attached, using arcs and push pull etc.
      Now I want to give it some body, on a flat surface push/pull would do exactly what I want.
      Where do I go from here to get some thickness. Have tried follow-me but could not get it to work. Maybe not doing it right.
      Thanks and regards
      Charlie
      SkirtFollowTool.skp
      • StilTegS Offline
        StilTeg
        Best solution I am thinking right now is to copy/move your surface, then fill the gaps ...
        SkirtFollowTool2.skp
        doing technical engineering on SketchUp ... without plugins
          sswcharlie
          Thanks for the idea. I will give it a try.
          Regards
          Charlie
          • Alan FraserA Offline
            Alan Fraser
            Search out the Joint Push/Pull plugin. It will do exactly what you require....ie. P/P curved surfaces.
            There are links on this thread to the latest versions of many of Fredos plugins.
            3D Figures
            • K Offline
              KarinaGM
              I used joint push pull http://forums.sketchucation.com/viewtopic.php?f=180&t=67082.jpg
              (tab to enter the options window) with the thikening option
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
              -Benjamín Franklin.**
