    Adding tubing to a wireframe object
    3 Posts 3 Posters 341 Views 3 Watching
      mchlmacdonald
      ok, say i have a wireframe design of something like so....
      http://farm6.static.flickr.com/5221/5615603272_de51fb2be0.jpg
      MiniBuggy Frame Bare by mchlmacdonald, on Flickr
      is there any way i can add tubing to this frame without doing each angle/curve individually????
      • BoxB Offline
        Lines to Tubes will do it for you.
        http://forums.sketchucation.com/viewtopic.php?t=12354
        • mitcorbM Offline
          mitcorb
          Tube Along Path will accomplish this also. There is also Pipe Along Path.
          Lines to Tubes and the two I mentioned have slightly different results under certain circumstances.
