    Selectionobserver
    13 Posts 4 Posters 1.3k Views 4 Watching
    • K
      kiesewetter
      Hallo!
      I tried to write a script that displays in the ruby window the name of the layer the entity is arranged at everytime it gets selected. After that the entity should be erased. I used the folling code an it didn't work...
      class Selbserver < Sketchup;;SelectionObserver
      def onSelectionAdded(sel)
      	sel.each{|e|
      	           layer=e.layer.name
      			   puts layer
      			   e.erase!
      sel=Sketchup.active_model.selection
      sel.add_observer Selbserver.new
      #to load it
      #load "C;/Users/tim/Desktop/observertest.rb"
      i have no idea, why nothing happens when i load the script an select an entity after that.
      thanks for your time.
      • TIGT
        You can't change the entities in a selection as you refer to it [like erasing them]!
        You could try sel**.to_a**.each{|e|... as that would take a clone of it as an array...... but no promises it'll work though...
        • Dan RathbunD
          Dan Rathbun
          Sketchup::SelectionObserver#onSelectionAdded() callback is NOT IMPLEMENTED. Use onSelectionBulkChange instead.
          I think it's best if the entity is removed from the selection set (not erased from the model.)
          module Kiesewetter
            @@sel_spy = nil
              def onSelectionBulkChange(sel)
                sa = sel.to_a
                sa.each{|e|
                  puts("#{e.class.name};#{e.object_id} on layer; #{e.layer.name}")
                  sel.remove(e)
              end # def callback
            end #class
            unless @@sel_spy
              @@sel_spy = Selbserver.new()
              Sketchup.active_model.selection.add_observer( @@sel_spy )
            #to load it
          end # module
          I'm not here much anymore.
          • TIGT
            As Dan says, make a list of the selected items, remove them from the selection and then erase them ?
            I hadn't spotted the method you used - .onBulk... is the one to use - the others are foobar...
            • K
              kiesewetter
              first of all, thank you guys.
              ok, the ...BulkChange observer responds.
              is it possible to delete instead of the entities in the selection every entity on a certain layer?
              • TIGT
                model=Sketchup.active_model layers=model.layers layername="Layer1"
                you decide which layer to use!
                model.active_entities.to_a.each{|e| next if not e.valid?; e.erase! if e.layer==layers[layername] }
                note how we make an array [.to_a] of the entities -
                you can't work on the entities directly AND change it - weird results will happen!
                the active_entities erases just things in that entities collection -
                that need not be model.entities, but could be group.entities or even definition.entities
                the e.valid? test avoids a crash -
                e.g. if you've erased an edge so its face no longer exists when we come to look at it!
                • K
                  kiesewetter
                  works with the faces, but all the lines aren't erased. any idea why?
                  • thomthomT
                    It'd be faster to fetch the reference to the layer you want to erase from before the loop. Retrieving a reference to a layer by looking up a string reference is slower.
                    <span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />layer&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'Layer1'</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layer&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">layer<br /></span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> </span>
                    • thomthomT
                      The edges aren't on the same layer?
                      • TIGT
                        They are not on the layer ?
                        To find an object's layer Select it and open Entity Info...
                        The code snippet I offered erases everything on a particular layer - it is not careful about things like if the edge goes so does its face even if that face is NOT on that layer...
                        It was a simplistic example - you can add all sorts of checks too.
                        If you only want to layer faces but erase their edges then use something like...
                        Firstly change it to
                        layer=layers[layername] ### as tt recommends...
                        then inside the 'each' loop...
                        if e.class==Sketchup;;Face and e.layer==layer
                          edges=e.edges
                          e.erase!
                          edges.each{|ed| ed.erase! if not ed.faces[0] }
                        which erases the face if it's on the specified layer... AND having made a list of that face's edges, it erases any of them that are now 'faceless' as a result...
                        • K
                          kiesewetter
                          the edges were on the same layer (tested it with test=e.layer; puts test)
                          could it be that lines only can be deleted, if they don't border a face?
                          i executed the script to delete the entities twice, in the first step only the faces were deleted. in the second step the lines were erased.
                          • thomthomT
                            Erasing an edge will also erase any connected faces.
                            • K
                              kiesewetter
                              hmmm... ok. in this case i don't understand why the lines behaved like that. not that important.
                              ok, thanks to you once again. 😄
