    Definition Observer
    6 Posts 3 Posters 691 Views 3 Watching
    • K Offline
      kwalkerman
      Hello,
      I'm trying to use definition observers in a script instead of multiple entities observers because they seem to be a little more stable. There are a number of quirky things about it, but one that I haven't been able to work around is as follows:
      When I add a component instance to the model, the onComponentInstanceAdded method fires. However, if I delete the component instance and then undo, onComponentInstance added does NOT fire. I need to be notified both of new instances and of instances that are back from the dead.
      Any ideas?
      Thanks a bunch,
      Karen
        Use a combination of definitions observer and definition observer.
        Add a definition observers to each of the definitions.
        When a definition is added/deleted to/from definitions you know.
        You now know that definition - add an observer to that too.
        When any definition has instances added/removed you know as its observer tells you...
        • K Offline
          kwalkerman
          except that onInstanceRemoved doesn't fire
          and onInstanceAdded doesn't fire for a delete-undo event
          ... I think I'm going back to entities observers... seems more stable in SU8
            Yea - definition observer has been troublesome all along: http://www.thomthom.net/software/sketchup/observers/#DefinitionObserver
              Crib from my '#HolePunchTool.rb'...
              That uses definition and definitions [and several other] observers, and a global [$] array of things that is adjusted as we go...
              It seems to work OK for me, to keep track of Hole-Punching Instances etc and control copying, etc...
              Have a look - the observers code is near the end of the script...
              You might be able to adjust its ideas to your needs... πŸ€“
              • K Offline
                kwalkerman
                Thanks TIG.
                TT - I revisited your observers chart page after posting the initial message. Definitely very helpful. Thanks for maintaining it.
                Karen
