    Best File Type to Export as for CNC Cutting?
    5 Posts 4 Posters 968 Views 4 Watching
    • C
      Click Draw
      Hello guys and gals,
      I have designed a kiosk that I plan on having all the parts cut by a CNC Router. Any advice on the best file type to export it as? I know EPS doesn't export to the proper size and scale. Thanks in advance.
      Cheers,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        Jeff, it would probably be a good idea to find out what software and file types the specific CNC machine uses to determine what you want to use for your export. Some CNC routers use proprietary software and may be able to convert SKP files directly or the link might be a DXF/DWG file out of SU.
        • D
          Dropout
          DXF if you can figure out how to do so (I can't). Most CNC machines can read or import DXF's.
          • C
            Click Draw
            Great! Thanks you guys.
            Cheers
            • T
              tfdesign
              Jeff, Sorry to come in a little late here, but actually the best type of file for CNC is .STL (Stereo Lithographic), which is the industry standard, not necessarily DXF/DWG. (although some routers do read DWG, but they tend to be of the very high end type)
              Tom
              My book "Let's SketchUp!" Download from here
