    Getting info from a text file
    5 Posts 3 Posters 696 Views 3 Watching
    • B
      borg.stef
      This is my code where im getting information from a text file. it is a loop like this: 0th line in variable machine (string), 1nd line in variable x (integer), 2rd line in variable y (integer), 3th line in var rot (integer), 4th line in machine again etc. however if in the string line there is "floor" written, those 4 lines will be skipped and go to the next string line (therefore counter = counter +4). However when i run it, nothing happens 😞
      	a = []
      	counter = 0
      	file = File.new("trial.txt", "r")
      	while (line = file.gets)
      		a[counter] = line
      		if counter % 4 == 0.0         # lines 0 , 4, 8 etc
      			if a[counter] = #{floor}
      				counter = counter + 4
      			 else machine = "#{a[counter].3ds"
      		elsif counter % 4 == 1.0    # lines 1 , 5, 9 etc
      			x = a[counter].to_f
      		elsif counter % 4 == 2.0     # lines 2 , 6, 10 etc
      			y = a[counter].to_f
      		elsif counter % 4 == 3.0    # lines 3 , 7, 11 etc
      			rot = a[counter].to_i
      • TIGT
        A much simpler way is to read all of the file's lines into an array like this
        lines=IO.readlines(file_path)
        then process the lines in turn...
        lines.each{|line| ...### do something to 'line' or use 'next' if it's not a type you want... }
        This way you don't need to open/close the file or use 'counters' etc...
        • Dan RathbunD
          Dan Rathbun
          But if you still wish to use a counter, you may by using the each_with_index iterator (that is mixed into the Array class, from module Enumerable.)
          lines.each_with_index {|line,counter| ...### do something to 'line' or use 'next' if it's not a type you want... }
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            The reason it does not work is this line:
            should be:
            if a[counter] == "floor"
            Because:
            (1) = is the assignment operator, and == is the equality method for class String.
            (2) the #{var} replacement operator must be nested within a double-quoted String literal.
            BUT... in your case, "floor" is NOT a variable (reference), it is a String value, so you just need to specify the literal String.
            • Dan RathbunD
              Dan Rathbun
              By the way... if YOU are creating the files.. why not simplify things and write out CSV records, where each line is:
              "string tag",x,y,rot
              We have a topic on reading CSV text files:
              [code] reading a CSV file
              EDIT: Oh you are using MatLab written files, as in this post http://forums.sketchucation.com/viewtopic.php?f=180&t=35961&start=30#p319047
