Getting info from a text file
5 Posts 3 Posters 420 Views 3 Watching
    borg.stef
    This is my code where im getting information from a text file. it is a loop like this: 0th line in variable machine (string), 1nd line in variable x (integer), 2rd line in variable y (integer), 3th line in var rot (integer), 4th line in machine again etc. however if in the string line there is "floor" written, those 4 lines will be skipped and go to the next string line (therefore counter = counter +4). However when i run it, nothing happens 😞
    	a = []
    	counter = 0
    	file = File.new("trial.txt", "r")
    	while (line = file.gets)
    		a[counter] = line
    		if counter % 4 == 0.0         # lines 0 , 4, 8 etc
    			if a[counter] = #{floor}
    				counter = counter + 4
    			 else machine = "#{a[counter].3ds"
    		elsif counter % 4 == 1.0    # lines 1 , 5, 9 etc
    			x = a[counter].to_f
    		elsif counter % 4 == 2.0     # lines 2 , 6, 10 etc
    			y = a[counter].to_f
    		elsif counter % 4 == 3.0    # lines 3 , 7, 11 etc
    			rot = a[counter].to_i
      A much simpler way is to read all of the file's lines into an array like this
      lines=IO.readlines(file_path)
      then process the lines in turn...
      lines.each{|line| ...### do something to 'line' or use 'next' if it's not a type you want... }
      This way you don't need to open/close the file or use 'counters' etc...
        Dan Rathbun
        But if you still wish to use a counter, you may by using the each_with_index iterator (that is mixed into the Array class, from module Enumerable.)
        lines.each_with_index {|line,counter| ...### do something to 'line' or use 'next' if it's not a type you want... }
        I'm not here much anymore.
          Dan Rathbun
          The reason it does not work is this line:
          should be:
          if a[counter] == "floor"
          Because:
          (1) = is the assignment operator, and == is the equality method for class String.
          (2) the #{var} replacement operator must be nested within a double-quoted String literal.
          BUT... in your case, "floor" is NOT a variable (reference), it is a String value, so you just need to specify the literal String.
            Dan Rathbun
            By the way... if YOU are creating the files.. why not simplify things and write out CSV records, where each line is:
            "string tag",x,y,rot
            We have a topic on reading CSV text files:
            [code] reading a CSV file
            EDIT: Oh you are using MatLab written files, as in this post http://forums.sketchucation.com/viewtopic.php?f=180&t=35961&start=30#p319047
