    Rendering 2d trees and people using v ray
    renderpluginsextensions
    2 Posts 2 Posters 2.1k Views 2 Watching
      sawhack
      hi,
      i have a problem rendering 2d trees and people but when rendering finished, it appears to be a picture or plane having 4 corners and trees within it. how i will remove the background of trees and make it transparent? so the building on the background was not being block.
      Saw
        bocomofo
        If you are using a jpeg you will have to manually cut out the background and save it as a png (with transparency). Once you have done that when using an image tick the check box marked 'use colour texture as transparency' under the diffuse rollout in the material editor.
        that worked for me!
