πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
JSON in Ruby
48 Posts 7 Posters 7.0k Views 7 Watching
    Dan Rathbun
    @myhand said:
    @aerilius said:
    please take a look and make use of the WebDialogX project.
    I cannot access the content. I get "You do not have access to the wiki." message, even after I have registered.
    Sorry, it is a 5-slot private repository at this time, and we really need very experienced Rubyists for the slots.
    And you are kinda re-inventing the wheel. Js has %(#8000BF)[escape()] and %(#8000BF)[unescape()], and Ruby has them in the URI library.
    See topic: http://sketchucation.com/forums/viewtopic.php?f=180&t=49183#p442102
    In fact I would vote for Ruby's URI::Escape module to be mixed into the SketchUp API UI::WebDialog class.
    I'm not here much anymore.
      Myhand
      No problem Dan, I only looked there as Aerilius recommended I do so.
      Thank you, I will try the URI library (I already use escape() in my latest JS code). I do not really want to reinvent the wheel, hence me asking the question here.
      http://www.keepingmyhandin.com/
        Myhand
        @aerilius said:
        1. You need to escape \ characters in the double-quoted javascript code that you want to bring into the webdialog (this first escaping is what makes a valid Ruby string).
          %(#000000)["alert('C:\users')"] # bad Ruby string
          %(#000000)["alert('C:\\users')"] # good Ruby string
        2. In the webdialog, the string arrives written in a script element. As always, the same escaping rules apply again:
          %(#000000)[alert('C:\users')] // bad JavaScript code
          %(#000000)[alert('C:\\users')] // good JavaScript code
        => So finally this means we need double escaping on the Ruby side!
        %(#000000)["alert('C:\\\\users')"] # Ruby string
        Thanks for a very clear explanation. πŸ‘ I tried this last night and it worked. Need 7 '''s for a "!
          What?
            Myhand
            Thanks for this Dan! It works well, and I do not need to remember the number of slashes. πŸ˜„
            I see that escape() and unescape() are deprecated though and that you are recommended to use
            decodeURI()
            decodeURIComponent()
            Which do you recommend or should I continue with unescape()?
              Myhand
              @thomthom said:
              What?
              Sorry, meant you need
              "a JSON escaped double quote need to be specified like this \\\\\\\" in Ruby for a WebDialog call"
              to produce
              "a JSON escaped double quote need to be specified like this \" in Ruby for a WebDialog call"
              as the parameter of the JS function called.
                Dan Rathbun
                Hmmm..
                given a Js function named say()
                .. and a Ruby string:
                jarg = %q('a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call')
                I usually do something like this:
                dlg.execute_script("say(#{jarg});")
                or I will leave the single quotes out of the jarg string, and put them in at the call ...
                jarg = %q(a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call.)
                dlg.execute_script( "say('" << jarg << "');" )
                πŸ’­
                  Dan Rathbun
                  [quote="Myhand":31wco2xd]I see that %(#8000BF)[escape()] and %(#8000BF)[unescape()] are deprecated (in Javascript,) though, and that you are recommending to use [them]
                  ***%(#BF4000)[
                  ](http://msdn.microsoft.com/en-us/library/dz4x90hk(v) ":31wco2xd]The unescape function should not be used to decode Uniform Resource Identifiers (URI). Use decodeURI and decodeURIComponent functions instead.
                  %(#8000BF)[decodeURI()]
                  %(#8000BF)[decodeURIComponent()]
                  Which do you recommend or should I continue with %(#8000BF)[unescape()]?
                  The old functions are ASCII, the new ones are Unicode.
                  Taking a look at the most recent released ECMA-262 (but not the latest proposed revision,) the old functions are no longer listed.
                  see: ECMA-262, 5.1, Global Object: 15.1.3 URI Handling Function Properties
                  ECMAScript Language Specification
                  Standard ECMA-262
                  5.1 Edition / June 2011
                  Link to the downloadable PDF of the specification .
                  But you need to handle the situation where an older browser does not have these functions so, write a wrapper in JS:
                  var unesc = function(uri) {
                      var test = false;
                      if (typeof(decodeURI) == "function") test = true;
                      return test ? decodeURI(uri) ; unescape(uri);
                  πŸ’­
                  • 3 / 3
                  3 / 3
