    JSON in Ruby
    48 Posts 7 Posters 9.4k Views 7 Watching
      Myhand
      OK, with the single quote now working, I have run into the next (and hopefully the last) problem. It appears as if the
      WebDialog.execute_script
      method strips all \ characters from its arguments as it passes it into JavaScript. I think it is because it does a eval() call on the JS.
      e.g.
      js_command = "material_maintenance.Sketchup.callUI(\"a string >\\< with a \\\" in the middle\")"; puts "js_command = #{js_command}";
      produces this in the Ruby console:
      js_command = material_maintenance.Sketchup.callUI("a string >\< with a \" in the middle")
      and this when you print the parameter to the callUI function as it hits JS.
      a string >< with a " in the middle
      replacing js_command with
      js_command = "material_maintenance.Sketchup.callUI(\"a string >\\u005c\\u0022< with a \\u005c\\u0022 in the middle\")"
      works and produces the desired output in JS
      a string >\"< with a \" in the middle
      but this feels a bit clunky. Any other ideas?
      http://www.keepingmyhandin.com/
        Aerilius
        1. You need to escape \ characters in the double-quoted javascript code that you want to bring into the webdialog (this first escaping is what makes a valid Ruby string).
          %(#000000)["alert('C:\users')"] # bad Ruby string
          %(#000000)["alert('C:\\users')"] # good Ruby string
        2. In the webdialog, the string arrives written in a script element. As always, the same escaping rules apply again:
          %(#000000)[alert('C:\users')] // bad JavaScript code
          %(#000000)[alert('C:\\users')] // good JavaScript code
        => So finally this means we need double escaping on the Ruby side!
        %(#000000)["alert('C:\\\\users')"] # Ruby string
        P.S: SketchUp does not offer error handling for syntax errors in the Ruby-to-JavaScript string. Assuming my js contains user generated data with unknown characters, or is broken (truncated), we will definitely get a popup about "Syntax Error" that we cannot suppress and handle in other ways. In order to get control of such errors, we could send the code as a JavaScript string and eval() it:
        %(#000000)[webdialog.execute_script("try{eval(\"}bad_$yn7aX{\")}catch(e){}")]
        All of this is an old story and to many people have suffered, discovered, solved this and re-invented the wheel. For an all-in-one solution that covers this and many other WebDialog issues (for example you will discovered that when sending \\\ from JS to Ruby, it randomly drops some ), please take a look and make use of the WebDialogX project.
          Almost - it injects a SCRIPT element in the webdialog - does pretty much the same thing.
          So when you pass data to the WebDialog and something is amiss - check the string you're sending to the WebDialog - is it valid? What throws people off is that you have the quoting needed to create the Ruby string with the JS - and within the JS string you need to follow JS's own quoting and escaping rules.
          (Because execute_script adds a SCRIPT element for every call I prefer to remove the SCRIPT element on the JS side afterwards - as I don't like the idea of the DOM tree flooded with SCRIPT elements. I've yet to experience problems with it - but there's something about it that makes my OCD-nerve tingle.)
            Myhand
            I am sure I tried this last night, but will do some further tests again tonight.
            [/size]
            Nice idea, I might use this going forward.
            I cannot access the content. I get "You do not have access to the wiki." message, even after I have registered.
            • Dan RathbunD Offline
              Dan Rathbun
              Sorry, it is a 5-slot private repository at this time, and we really need very experienced Rubyists for the slots.
              And you are kinda re-inventing the wheel. Js has %(#8000BF)[escape()] and %(#8000BF)[unescape()], and Ruby has them in the URI library.
              See topic: http://sketchucation.com/forums/viewtopic.php?f=180&t=49183#p442102
              In fact I would vote for Ruby's URI::Escape module to be mixed into the SketchUp API UI::WebDialog class.
              I'm not here much anymore.
                Myhand
                No problem Dan, I only looked there as Aerilius recommended I do so.
                Thank you, I will try the URI library (I already use escape() in my latest JS code). I do not really want to reinvent the wheel, hence me asking the question here.
                  Myhand
                  Thanks for a very clear explanation. πŸ‘ I tried this last night and it worked. Need 7 '''s for a "!
                    What?
                      Myhand
                      Thanks for this Dan! It works well, and I do not need to remember the number of slashes. πŸ˜„
                      I see that escape() and unescape() are deprecated though and that you are recommended to use
                      decodeURI()
                      decodeURIComponent()
                      Which do you recommend or should I continue with unescape()?
                        Myhand
                        @thomthom said:
                        What?
                        Sorry, meant you need
                        "a JSON escaped double quote need to be specified like this \\\\\\\" in Ruby for a WebDialog call"
                        to produce
                        "a JSON escaped double quote need to be specified like this \" in Ruby for a WebDialog call"
                        as the parameter of the JS function called.
                          Dan Rathbun
                          Hmmm..
                          given a Js function named say()
                          .. and a Ruby string:
                          jarg = %q('a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call')
                          I usually do something like this:
                          dlg.execute_script("say(#{jarg});")
                          or I will leave the single quotes out of the jarg string, and put them in at the call ...
                          jarg = %q(a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call.)
                          dlg.execute_script( "say('" << jarg << "');" )
                          πŸ’­
                            Dan Rathbun
                            [quote="Myhand":31wco2xd]I see that %(#8000BF)[escape()] and %(#8000BF)[unescape()] are deprecated (in Javascript,) though, and that you are recommending to use [them]
                            ***%(#BF4000)[
                            ](http://msdn.microsoft.com/en-us/library/dz4x90hk(v)":31wco2xd]The unescape function should not be used to decode Uniform Resource Identifiers (URI). Use decodeURI and decodeURIComponent functions instead.
                            %(#8000BF)[decodeURI()]
                            %(#8000BF)[decodeURIComponent()]
                            Which do you recommend or should I continue with %(#8000BF)[unescape()]?
                            The old functions are ASCII, the new ones are Unicode.
                            Taking a look at the most recent released ECMA-262 (but not the latest proposed revision,) the old functions are no longer listed.
                            see: ECMA-262, 5.1, Global Object: 15.1.3 URI Handling Function Properties
                            ECMAScript Language Specification
                            Standard ECMA-262
                            5.1 Edition / June 2011
                            Link to the downloadable PDF of the specification.
                            But you need to handle the situation where an older browser does not have these functions so, write a wrapper in JS:
                            var unesc = function(uri) {
                                var test = false;
                                if (typeof(decodeURI) == "function") test = true;
                                return test ? decodeURI(uri) ; unescape(uri);
                            πŸ’­
                            • 3 / 3
