JSON in Ruby
@myhand said:
Thanks OricAtmos! Will give it a try.
Did you get it to work? Unfortunately I've been unsuccessful in finding out where I got it from.
Sorry, I got a bit tied up with trying to solve the MAC bug in my Material_Maintenance Plugin.
Thank you, I have now got it to not throw an error, but my test code does not seem to serialise objects, so will need to read the library docs to see what I am doing wrong
` require 'yajl'
h = {"key1", "val1", "key2", "val2"};
obj = ["Hello", "world", "I am here", ["where", "what", "are", "you"]];
class TestClass
@name = nil;
@adress = nil;
@list = nil;def initialize(p1, p2)
@name, @adress = p1, p2;
@list = [1,2,3.01,-4.35];
endend
t = TestClass.new("Richo", "37 Scotland Rd, Buckhurst Hill, IG9 5NP");
obj = ["Hello", "world", t, "I am here", ["where", "what", "are", "you"]];
str = Yajl::Encoder.encode(obj);
puts str;`
Produces
["Hello","world","#<TestClass;0x144d9cc0>","I am here",["where","what","are","you"]]
Instead of the
["Hello","world",{"@list";[1,2,3.01,-4.35],"@name";"Richo","@adress";"37 Scotland Rd, Buckhurst Hill, IG9 5NP"},"I am here",["where","what","are","you"]]
I would expect and which is what my simple JSON Serializer produces.
Hi OricAtmos,
I got it to work now thank you. It seems that it can only serialise Hash and Array objects though, which is good enough for most cases I guess. Given the non-trivial install and given the fact that it uses binary libraries, I suspect it will not work on a MAC either without libraries built for that.
I will therefore continue with my simple JSON encoder, which while probably much slower, is simple to install and should work out of the box on a MAC as it is pure RUBY. It can also encode standard objects which can be useful.
Thanks for your help in getting this working though. I will keep it in mind if I ever have to do large data sets.
All right, I wasn't aware Yajl isn't able to work with arbitrary objects. I was only using it to encode/decode hashes with simple values and arrays.
Hi guys,
I need some help. I have run into problems creating a json encoding where a string contains a single quote char. e.g. "Betty's pie shop"
somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
puts "Betty's pie shop"
and I get
Betts pie shops pie shop
if you past this into an editor that supports UTF8 you see that a special char has been added into where the y and ' was. Also note that the last bit of the string is now duplicated.
I can escape it, but this is then not a valid json string as json does not allow you to escape the ' char.
May be your encoding... only fails with single quotes here
> puts "Betty's pie shop" Betty's pie shop nil > p "Betty's pie shop" "Betty's pie shop" nil > print "Betty's pie shop\n" Betty's pie shop nil > print 'Betty's pie shop\n' Error; #<SyntaxError; (eval); compile error (eval); parse error, unexpected tIDENTIFIER, expecting $ print 'Betty's pie shop\n' ^> (eval)
john
@myhand said:
... somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
and I get:
%(#008000)[>> Betts pie shops pie shop]
At the SketchUp Ruby Console:
` puts "Betty's pie shop"
>> Betty's pie shopputs "Betty's pie shop".inspect()
>> "Betty's pie shop"puts "Betty's pie shop".inspect().inspect()
>> ""Betty's pie shop""` -
s = %q(Dan's friggin' advice, "Hey, use Ruby's % lowercase 'q' interpretive delimiter. It's a great help when your bleepin' strings have "'" and '"' characters in them!")
%Q
and%
is a double-quoted string. You can choose any 2 delimeters you want.name = %$MyHand$
str = %q{I want some quotes right "HERE"! Let's go.}
johnThought so too initially. But I got the same results by typing straight into the Sketchup Ruby console... Can you set encoding at the Sketchup level?
>> ""Betty's pie shop""`This works for me today on my work PC. So must be something specific with my Sketchup installation/version at home. Both are Version 8 out of the box installations on Windows. The one that corrupts the "'" char is the Pro addition, while the one at work is the Standard edition.
%Q
and%
Thank you Dan, I will give this a go tonight. As you might have guessed though the actual string I am having problems with (not the pie shop one
) is ComponentDefinition name field. Something like "Bath 6'x34"x54"". So I never actually input the string, I am just reading it. So I am not sure how I will use the above technique to step around the problem. Will have to give it some thought.
Disable ALL plugins and libraries, (Sketchup::plugins_disabled=true , close SketchUp and restart,) then try again ...
If it works, then you've installed a plugin that changes the
String
base class. A very big no-no, in a shared Ruby environment, such as SketchUp embedded Ruby (or DoubleCAD XT embedded Ruby, etc.)In a normal "system" Ruby script, changing a base class doesn't matter because (99% of the time,) a script runs in it's own temporary Ruby process, finishes, and the Ruby process exits.
So.. the most likely culprit would be a library that is written to run temporarily in "system" Ruby, such as
Yajl
, or the standardJSON
library, that changes theString
class, or the global methods in mixin moduleKernel
(such asputs
,) or even stream classes, likeIO
.Encoding. It is set to UTF-8 by SketchUp just after it loads the interpreter. It should stay that way. Changing it via
$KCODE
is not a good idea as that (editable) feature has been removed in newer Ruby versions. (You'd just set your code up to fail in a newer SketchUp version if it distro's with Ruby v1.9.x) -
Do you have the SketchUp Developer Tools installed? (https://github.com/thomthom/sketchup-developer-tools ) Might be that it's interfering.
Try with just your plugin installed.
Thanks guys, I will give this a go tonight. Yes I do have the SketchUp Developer Tools installed.
@myhand said:
... is
ComponentDefinition
name field. Something like "Bath 6'x34"x54"".OK.. yea that reminds me. We have similar problems with SketchUp's formatted Length strings when saving things into the registry with
Sketchup::write_default()
andSketchup::read_default()
methods.There are some topics on that and using
gsub()
andtr()
before writing values.
The situation is similar because we also get these values with embedded single quotes from the application. -
Yup it was the SketchUp Developer Tools. Disabling that fixed the problem thanks.
OK, with the single quote now working, I have run into the next (and hopefully the last) problem. It appears as if the
WebDialog.execute_script
method strips all \ characters from its arguments as it passes it into JavaScript. I think it is because it does a eval() call on the JS.
e.g.
js_command = "material_maintenance.Sketchup.callUI(\"a string >\\< with a \\\" in the middle\")"; puts "js_command = #{js_command}";
produces this in the Ruby console:
js_command = material_maintenance.Sketchup.callUI("a string >\< with a \" in the middle")
and this when you print the parameter to the callUI function as it hits JS.
a string >< with a " in the middle
replacing js_command with
js_command = "material_maintenance.Sketchup.callUI(\"a string >\\u005c\\u0022< with a \\u005c\\u0022 in the middle\")"
works and produces the desired output in JS
a string >\"< with a \" in the middle
but this feels a bit clunky. Any other ideas?
- You need to escape \ characters in the double-quoted javascript code that you want to bring into the webdialog (this first escaping is what makes a valid Ruby string).
%(#000000)["alert('C:\users')"] # bad Ruby string
%(#000000)["alert('C:\\users')"] # good Ruby string
- In the webdialog, the string arrives written in a script element. As always, the same escaping rules apply again:
%(#000000)[alert('C:\users')] // bad JavaScript code
%(#000000)[alert('C:\\users')] // good JavaScript code
=> So finally this means we need double escaping on the Ruby side!
%(#000000)["alert('C:\\\\users')"] # Ruby string
P.S: SketchUp does not offer error handling for syntax errors in the Ruby-to-JavaScript string. Assuming my js contains user generated data with unknown characters, or is broken (truncated), we will definitely get a popup about "Syntax Error" that we cannot suppress and handle in other ways. In order to get control of such errors, we could send the code as a JavaScript string and eval() it:
%(#000000)[webdialog.execute_script("try{eval(\"}bad_$yn7aX{\")}catch(e){}")]
All of this is an old story and to many people have suffered, discovered, solved this and re-invented the wheel. For an all-in-one solution that covers this and many other WebDialog issues (for example you will discovered that when sending \\\ from JS to Ruby, it randomly drops some ), please take a look and make use of the WebDialogX project.
Almost - it injects a SCRIPT element in the webdialog - does pretty much the same thing.
So when you pass data to the WebDialog and something is amiss - check the string you're sending to the WebDialog - is it valid? What throws people off is that you have the quoting needed to create the Ruby string with the JS - and within the JS string you need to follow JS's own quoting and escaping rules.(Because execute_script adds a SCRIPT element for every call I prefer to remove the SCRIPT element on the JS side afterwards - as I don't like the idea of the DOM tree flooded with SCRIPT elements. I've yet to experience problems with it - but there's something about it that makes my OCD-nerve tingle.)
I am sure I tried this last night, but will do some further tests again tonight.
[/size]Nice idea, I might use this going forward.
I cannot access the content. I get "You do not have access to the wiki." message, even after I have registered.
