    JSON in Ruby
    48 Posts 7 Posters 10.3k Views 7 Watching
    • OricAtmosO
      OricAtmos
      @myhand said:
      Thanks OricAtmos! Will give it a try.
      Did you get it to work? Unfortunately I've been unsuccessful in finding out where I got it from.
        Myhand
        Sorry, I got a bit tied up with trying to solve the MAC bug in my Material_Maintenance Plugin.
        Thank you, I have now got it to not throw an error, but my test code does not seem to serialise objects, so will need to read the library docs to see what I am doing wrong
        ` require 'yajl'
        h = {"key1", "val1", "key2", "val2"};
        obj = ["Hello", "world", "I am here", ["where", "what", "are", "you"]];
        class TestClass
        @name = nil;
        @adress = nil;
        @list = nil;
        def initialize(p1, p2)
        @name, @adress = p1, p2;
        @list = [1,2,3.01,-4.35];
        t = TestClass.new("Richo", "37 Scotland Rd, Buckhurst Hill, IG9 5NP");
        obj = ["Hello", "world", t, "I am here", ["where", "what", "are", "you"]];
        str = Yajl::Encoder.encode(obj);
        puts str;`
        Produces
        ["Hello","world","#<TestClass;0x144d9cc0>","I am here",["where","what","are","you"]]
        Instead of the
        ["Hello","world",{"@list";[1,2,3.01,-4.35],"@name";"Richo","@adress";"37 Scotland Rd, Buckhurst Hill, IG9 5NP"},"I am here",["where","what","are","you"]]
        I would expect and which is what my simple JSON Serializer produces.
        http://www.keepingmyhandin.com/
          Myhand
          Hi OricAtmos,
          I got it to work now thank you. It seems that it can only serialise Hash and Array objects though, which is good enough for most cases I guess. Given the non-trivial install and given the fact that it uses binary libraries, I suspect it will not work on a MAC either without libraries built for that.
          I will therefore continue with my simple JSON encoder, which while probably much slower, is simple to install and should work out of the box on a MAC as it is pure RUBY. It can also encode standard objects which can be useful.
          Thanks for your help in getting this working though. I will keep it in mind if I ever have to do large data sets.
          • OricAtmosO
            OricAtmos
            All right, I wasn't aware Yajl isn't able to work with arbitrary objects. I was only using it to encode/decode hashes with simple values and arrays.
              Myhand
              Hi guys,
              I need some help. I have run into problems creating a json encoding where a string contains a single quote char. e.g. "Betty's pie shop"
              somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
              puts "Betty's pie shop"
              and I get
              Betts pie shops pie shop
              if you past this into an editor that supports UTF8 you see that a special char has been added into where the y and ' was. Also note that the last bit of the string is now duplicated.
              I can escape it, but this is then not a valid json string as json does not allow you to escape the ' char.
                driven
                May be your encoding... only fails with single quotes here
                Betty's pie shop
                nil
                > p "Betty's pie shop"
                "Betty's pie shop"
                nil
                > print "Betty's pie shop\n"
                Betty's pie shop
                nil
                > print 'Betty's pie shop\n'
                Error; #<SyntaxError; (eval); compile error
                (eval); parse error, unexpected tIDENTIFIER, expecting $
                (eval)
                • Dan RathbunD
                  Dan Rathbun
                  @myhand said:
                  ... somehow ruby creates a new char which replaces the y and the '. You can see this by executing the following command:
                  and I get:
                  %(#008000)[>> Betts pie shops pie shop]
                  At the SketchUp Ruby Console:
                  ` puts "Betty's pie shop"
                  >> Betty's pie shop
                  puts "Betty's pie shop".inspect()
                  >> "Betty's pie shop"
                  puts "Betty's pie shop".inspect().inspect()
                  >> ""Betty's pie shop""`
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    s = %q(Dan's friggin' advice, "Hey, use Ruby's % lowercase 'q' interpretive delimiter. It's a great help when your bleepin' strings have "'" and '"' characters in them!")
                    %Q and % is a double-quoted string. You can choose any 2 delimeters you want.
                    name = %$MyHand$
                    str = %q{I want some quotes right "HERE"! Let's go.}
                      Myhand
                      Thought so too initially. But I got the same results by typing straight into the Sketchup Ruby console... Can you set encoding at the Sketchup level?
                        Myhand
                        >> Betty's pie shop
                        >> "Betty's pie shop"
                        This works for me today on my work PC. So must be something specific with my Sketchup installation/version at home. Both are Version 8 out of the box installations on Windows. The one that corrupts the "'" char is the Pro addition, while the one at work is the Standard edition.
                          Myhand
                          name = %$MyHand$
                          Thank you Dan, I will give this a go tonight. As you might have guessed though the actual string I am having problems with (not the pie shop one 😉) is ComponentDefinition name field. Something like "Bath 6'x34"x54"". So I never actually input the string, I am just reading it. So I am not sure how I will use the above technique to step around the problem. Will have to give it some thought.
                          • Dan RathbunD
                            Dan Rathbun
                            Disable ALL plugins and libraries, (Sketchup::plugins_disabled=true, close SketchUp and restart,) then try again ...
                            If it works, then you've installed a plugin that changes the String base class. A very big no-no, in a shared Ruby environment, such as SketchUp embedded Ruby (or DoubleCAD XT embedded Ruby, etc.)
                            In a normal "system" Ruby script, changing a base class doesn't matter because (99% of the time,) a script runs in it's own temporary Ruby process, finishes, and the Ruby process exits.
                            So.. the most likely culprit would be a library that is written to run temporarily in "system" Ruby, such as Yajl, or the standard JSON library, that changes the String class, or the global methods in mixin module Kernel (such as puts,) or even stream classes, like IO.
                            Encoding. It is set to UTF-8 by SketchUp just after it loads the interpreter. It should stay that way. Changing it via $KCODE is not a good idea as that (editable) feature has been removed in newer Ruby versions. (You'd just set your code up to fail in a newer SketchUp version if it distro's with Ruby v1.9.x)
                              Do you have the SketchUp Developer Tools installed? (https://github.com/thomthom/sketchup-developer-tools) Might be that it's interfering.
                              Try with just your plugin installed.
                                Myhand
                                Thanks guys, I will give this a go tonight. Yes I do have the SketchUp Developer Tools installed.
                                • Dan RathbunD
                                  Dan Rathbun
                                  @myhand said:
                                  ... is ComponentDefinition name field. Something like "Bath 6'x34"x54"".
                                  OK.. yea that reminds me. We have similar problems with SketchUp's formatted Length strings when saving things into the registry with Sketchup::write_default() and Sketchup::read_default() methods.
                                  There are some topics on that and using gsub() and tr() before writing values.
                                  The situation is similar because we also get these values with embedded single quotes from the application.
                                    Myhand
                                    Yup it was the SketchUp Developer Tools. Disabling that fixed the problem thanks.
                                      Myhand
                                      OK, with the single quote now working, I have run into the next (and hopefully the last) problem. It appears as if the
                                      WebDialog.execute_script
                                      method strips all \ characters from its arguments as it passes it into JavaScript. I think it is because it does a eval() call on the JS.
                                      e.g.
                                      js_command = "material_maintenance.Sketchup.callUI(\"a string >\\< with a \\\" in the middle\")"; puts "js_command = #{js_command}";
                                      produces this in the Ruby console:
                                      js_command = material_maintenance.Sketchup.callUI("a string >\< with a \" in the middle")
                                      and this when you print the parameter to the callUI function as it hits JS.
                                      a string >< with a " in the middle
                                      replacing js_command with
                                      js_command = "material_maintenance.Sketchup.callUI(\"a string >\\u005c\\u0022< with a \\u005c\\u0022 in the middle\")"
                                      works and produces the desired output in JS
                                      a string >\"< with a \" in the middle
                                      but this feels a bit clunky. Any other ideas?
                                        Aerilius
                                        1. You need to escape \ characters in the double-quoted javascript code that you want to bring into the webdialog (this first escaping is what makes a valid Ruby string).
                                          %(#000000)["alert('C:\users')"] # bad Ruby string
                                          %(#000000)["alert('C:\\users')"] # good Ruby string
                                        2. In the webdialog, the string arrives written in a script element. As always, the same escaping rules apply again:
                                          %(#000000)[alert('C:\users')] // bad JavaScript code
                                          %(#000000)[alert('C:\\users')] // good JavaScript code
                                        => So finally this means we need double escaping on the Ruby side!
                                        %(#000000)["alert('C:\\\\users')"] # Ruby string
                                        P.S: SketchUp does not offer error handling for syntax errors in the Ruby-to-JavaScript string. Assuming my js contains user generated data with unknown characters, or is broken (truncated), we will definitely get a popup about "Syntax Error" that we cannot suppress and handle in other ways. In order to get control of such errors, we could send the code as a JavaScript string and eval() it:
                                        %(#000000)[webdialog.execute_script("try{eval(\"}bad_$yn7aX{\")}catch(e){}")]
                                        All of this is an old story and to many people have suffered, discovered, solved this and re-invented the wheel. For an all-in-one solution that covers this and many other WebDialog issues (for example you will discovered that when sending \\\ from JS to Ruby, it randomly drops some ), please take a look and make use of the WebDialogX project.
                                          Almost - it injects a SCRIPT element in the webdialog - does pretty much the same thing.
                                          So when you pass data to the WebDialog and something is amiss - check the string you're sending to the WebDialog - is it valid? What throws people off is that you have the quoting needed to create the Ruby string with the JS - and within the JS string you need to follow JS's own quoting and escaping rules.
                                          (Because execute_script adds a SCRIPT element for every call I prefer to remove the SCRIPT element on the JS side afterwards - as I don't like the idea of the DOM tree flooded with SCRIPT elements. I've yet to experience problems with it - but there's something about it that makes my OCD-nerve tingle.)
                                            Myhand
                                            I am sure I tried this last night, but will do some further tests again tonight.
                                            [/size]
                                            Nice idea, I might use this going forward.
                                            I cannot access the content. I get "You do not have access to the wiki." message, even after I have registered.
                                            • 2 / 3
