    Taking a model to particular coordinates
    44 Posts 5 Posters 2.2k Views 5 Watching
      No problem... "God loves a trier..."
      Here's a version that does work !
      I've never had to do this myself and I have written hundreds of scripts - so we all have things to learn πŸ˜’
      It now imports the 3ds file and places one instance at random, then adds one at the origin [0,0,0].
      It deletes the original one instances[0] and leaves the next one and then moves it by x/y values you have set at the start...
          model = Sketchup.active_model
          x=0 ### set x and y as needed...
          y=10.m
          defs=model.definitions.to_a
          machine = "C;\\Temp\\trial.3ds"
          model.import(machine,true)
          defa=model.definitions.to_a - defs ### what you just added
          defn=defa[0]
          defn.instances[0].erase!
          tr=Geom;;Transformation.new(ORIGIN)
          obj=model.active_entities.add_instance(defn, tr)
          pt=Geom;;Vector3d.new(x, y, 0)
          tr=Geom;;Transformation.translation(pt)
          obj.transform!(tr)
      We all learn! πŸ˜„
        borg.stef
        wow this actually worked....only that z is high up not 0..
        • Rich O BrienR Online
          Is this a 3ds importer that doesn't need you to place the model after importing? Or what is it?
            borg.stef
            rich, it imports a model and instantly takes it to particular coordinates dictated by you!
              The code as it stands adds a component-instance based on the 3ds file at the origin [0,0,0]... after all of the kerfuffle.
              It then moves it by the defined x & y values, the z isn't changed at all.
              IF the original object is not z=0, then it simply stays where it is in the 3ds file ???
              There are ways to move all of the definitions geometry to z=0 BUT that's not the original request ?
              Please check the 3ds's geometry and the SKP's for similarities if x=0 & y=0...
                This 3ds importer [built-in] DOES require you to place it BUT my cludged work-around does work... just about πŸ˜’
                  Can it place the 3ds file by lowest point of bounding box centre at 0,0,0? I'm not at pc to check this out?
                    Yes it could... BUT currently it simply moves it in x/y...
                    If I'm asked the right questions I might give the right answers... πŸ˜‰
                      borg.stef
                      How can the model alwayx go to z = 0?
                        First off... do the code as before, but leave x=0 and y=0.
                        What is the z ?
                        If that's known then add the -z in Vector3d.new(x, y, -z)
                        It should fix it.
                        BUT IF it's not easily known then perhaps use z=obj.bounds.min.z
                        and then re-transform! the obj using a new vector of (0,0,-z)...........
                          Audible sigh.....
                            Audible sigh.....
                            BUT we will sort this out [eventually... πŸ˜’ ]
                              @tig said:
                              @gaieus said:
                              And you have all the powers to move any topic belonging there, TIG!
                              πŸ˜„
                              I know but hopefully, this is now 'dead' so moving it now seems a waste of time... πŸ˜’
                              Ah yes, so the topic has grown to 3 pages ever since.
                              πŸ˜‰
                              Anyway, looking forward to the "doh" moment (not as if I understood any of the discussion here - maybe except for Rich's gibbering)
                              πŸ˜’
                                Aaah, look who's cheered up. Did you find your little unwelcome friend?
                                  @gaieus said:
                                  @tig said:
                                  πŸ˜„
                                  πŸ˜‰
                                  πŸ˜’
                                  The announcement of the demise of the topic was a little premature [to paraphrase Mark Twain [again]]...
                                  There's also the PMing that you don't see πŸ˜’
                                    borg.stef
                                    This programm is actually making me crazy. What I am doing is that Matlab gives me a list example like this in a text file.
                                    milling
                                    500 (x axis)
                                    400 (y axis)
                                    0 (rot)
                                    drilling
                                    600
                                    .....etc
                                    and then I use this text file in the program above. However it gives me an error: Failed import. strangely enough when I remove the first name and its coordinates and rotation and moves the second one in its place, it works. Do you think this is a problem about the matlab code or sketchup?
                                      You give us no real example but expect us to help you...
                                      Can you attach a typical file so we can understand what you are trying to extract from the file...
                                      IF the format is as your post suggests...
                                      milling
                                      500 (x axis)
                                      400 (y axis)
                                      0 (rot)
                                      drilling
                                      600 THEN your code needs to find 'milling' and then after that the next two lines are X, Y & the third line 'rot' give your values '.to_f'; when you meet another 'milling' you stop and start again. If you meet another 'drilling' you stop and take a value '.to_f' from the drilling [whatever that is?] etc...
                                      IF you give us an example of the file you are wanting to read in, and what you hope to get out of it to put into your SKP THEN we might be better placed to help you - rather than this current 'bits & bobs' approach which isn't getting anyone anywhere... πŸ˜’
                                        borg.stef
                                        ok sorry so let me explain better. So I did a text file containing the following:
                                        milling
                                        500
                                        400
                                        drilling
                                        650
                                        100
                                        90
                                        etc....
                                        then the sketchup plugin opens this text file and read line by line. the first line is the name of a .3ds file and it is imported. 500 and 400 are the x and y coordinates where the model will be taken and 0 is the rotation of the model. then it starts again..imports the file drilling.3ds and takes it at 650, 100 and rotates it by 90 degrees.
                                        Till then it's ok.
                                        Now what i had to do is generate the text file using Mathlab and I managed to do that. However when I load this file (generated by matlab) in sketchup it tells me import failed. Then, if I delete the name of the first model, it's x and y coordinates and the rotation ie as below
                                        drilling
                                        650
                                        100
                                        90
                                        etc
                                        It imports al the models correctly.. I don't know if the error is from matlab's side or sketchup's. I hope i explained myself wel now...
                                          So...
                                          You have data in a file that always has 4 lines for each 'thing'.
                                          The first line is the file-name.
                                          The second line is the X.
                                          The third line is the Y.
                                          The fourth line is the Rotation.
                                          So you need to read the file in steps of four...
                                          lines=IO.readlines(filepath)
                                          i=0 ### always the first element in array 'lines'
                                          (lines.length/4).times{
                                            f=lines[i].strip
                                            ###the '.strip' ### removes '\n'; does it need +'.3ds' ???
                                            x=lines[i+1].strip.to_f
                                            y=lines[i+2].strip.to_f
                                            r=lines[i+3].strip.to_f
                                            ### now do what you want with file 'f',
                                            ### placing it at 'x' & 'y' with rotation 'r' etc...
                                            i=i+4 ### do next 4 lines etc etc...
                                          I suspect that you might not be doing the import successfully ???
                                            borg.stef
                                            and where do i write the name of hte file?
                                            • 2 / 3
