    Taking a model to particular coordinates
    44 Posts 5 Posters 4.5k Views 5 Watching
    • B
      borg.stef
      I copy and pasted the code that you gave me and I tried x = 0 y = 0 and even x= 0 y = 100.m but it's doing the same in both cases. Importing the model in a random location. I'm so confused.
        So am I.
        Can you attach your 3ds file to a post or a Private Message [PM] and I'll look at it...
        • B
          borg.stef
          it shows this message: The extension 3ds is not allowed. 😞
          • B
            borg.stef
            it shows this message : The extension 3ds is not allowed.
              Don't worry about the example 3ds [but you could 'zip' that type of file]... I've found the problem. 3ds files import but expect you to pick an insertion point - some file type imports don't... I'm thinking how to circumvent this...
              • B
                borg.stef
                Thanks for your time...you know I'm new to ruby I don't know these details...just built programs from what i found on the net..thanks!
                • B
                  borg.stef
                  i can't seem to make this thing work 😒
                    No problem... "God loves a trier..."
                    Here's a version that does work !
                    I've never had to do this myself and I have written hundreds of scripts - so we all have things to learn πŸ˜’
                    It now imports the 3ds file and places one instance at random, then adds one at the origin [0,0,0].
                    It deletes the original one instances[0] and leaves the next one and then moves it by x/y values you have set at the start...
                        model = Sketchup.active_model
                        x=0 ### set x and y as needed...
                        y=10.m
                        defs=model.definitions.to_a
                        machine = "C;\\Temp\\trial.3ds"
                        model.import(machine,true)
                        defa=model.definitions.to_a - defs ### what you just added
                        defn=defa[0]
                        defn.instances[0].erase!
                        tr=Geom;;Transformation.new(ORIGIN)
                        obj=model.active_entities.add_instance(defn, tr)
                        pt=Geom;;Vector3d.new(x, y, 0)
                        tr=Geom;;Transformation.translation(pt)
                        obj.transform!(tr)
                    We all learn! πŸ˜„
                    • B
                      borg.stef
                      wow this actually worked....only that z is high up not 0..
                        Is this a 3ds importer that doesn't need you to place the model after importing? Or what is it?
                        • B
                          borg.stef
                          rich, it imports a model and instantly takes it to particular coordinates dictated by you!
                            The code as it stands adds a component-instance based on the 3ds file at the origin [0,0,0]... after all of the kerfuffle.
                            It then moves it by the defined x & y values, the z isn't changed at all.
                            IF the original object is not z=0, then it simply stays where it is in the 3ds file ???
                            There are ways to move all of the definitions geometry to z=0 BUT that's not the original request ?
                            Please check the 3ds's geometry and the SKP's for similarities if x=0 & y=0...
                              This 3ds importer [built-in] DOES require you to place it BUT my cludged work-around does work... just about πŸ˜’
                                Can it place the 3ds file by lowest point of bounding box centre at 0,0,0? I'm not at pc to check this out?
                                  Yes it could... BUT currently it simply moves it in x/y...
                                  If I'm asked the right questions I might give the right answers... πŸ˜‰
                                  • B
                                    borg.stef
                                    How can the model alwayx go to z = 0?
                                      First off... do the code as before, but leave x=0 and y=0.
                                      What is the z ?
                                      If that's known then add the -z in Vector3d.new(x, y, -z)
                                      It should fix it.
                                      BUT IF it's not easily known then perhaps use z=obj.bounds.min.z
                                      and then re-transform! the obj using a new vector of (0,0,-z)...........
                                        Audible sigh.....
                                          Audible sigh.....
                                          BUT we will sort this out [eventually... πŸ˜’ ]
                                          • GaieusG
                                            @tig said:
                                            @gaieus said:
                                            And you have all the powers to move any topic belonging there, TIG!
                                            πŸ˜„
                                            I know but hopefully, this is now 'dead' so moving it now seems a waste of time... πŸ˜’
                                            Ah yes, so the topic has grown to 3 pages ever since.
                                            πŸ˜‰
                                            Anyway, looking forward to the "doh" moment (not as if I understood any of the discussion here - maybe except for Rich's gibbering)
                                            πŸ˜’
                                            • 2 / 3
