    SU 8 Mac & strange content
    6 Posts 3 Posters 976 Views 3 Watching
      tomasz
      Error: #<NoMethodError: undefined method layer' for #<Sketchup::RenderingOptions:0x1cc090c4>> (eval):2537:in collect_faces'
      This is a dump of a Ruby console, when an exporter stopped with the error.
      The 'collect_faces' method browse through Sketchup.active_model.entities or through a selection.
      How is it possible that suddenly Sketchup::RenderingOptions:0x1cc090c4 are part of entities, among edges, faces, groups and components?
      Has anyone experienced similar thing on Mac? I haven't spotted such a strange content in Windows version.
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        What export tool were you running when the error appeared ?
        Is it repeatable ?
        Did the export complete OK or fail ?
        Does it only happen with a certain SKP or consistently ?
        Is there anything 'unusual' about the SKP ? e.g. very big, very small, many textures, unusual rendering settings, fog etc...
        • Dan RathbunD Offline
          Dan Rathbun
          The simpliest explanation would be that you have a reference error. Somehow the reference variable you are using to walk the entities is also being set to refer to a Sketchup::RenderingOptions object, which can be for the active_model or a Scene(Page) object.
          Make sure if you are within a method, collect_faces() that you use unique var names. Use a different var name for accessing the rendering options than you do for walking the entities.
          Also you can do Type checking... check the return type from your method:
          ret = collect_faces()
          if ret.is_a?(Array) && ret.all?{|member| member.kind_of?(Sketchup;;Drawingelement) }
            # do code
          else
            # recover code, such as slicing non-drawingelement
            # members out of the array
          I also notice you are getting a "eval:line number" in the exception error. If this error is occuring in a scrambled rbs file.. you should load and debug your non-scrambled version, which should return the file and line number where the error is occuring.
          I'm not here much anymore.
            Dan Rathbun
            There is an error in the APC docs for Sketchup::RenderingOptions.
            The superclass of Sketchup::RenderingOptions is Sketchup::Entity, not Object.
            Also, .parent() does not work for Sketchup::RenderingOptions instances. It returns nil.
            It would be nice if .parent() returned the model for the model's rendering options hash, and the specific Sketchup::Page object for a scenepage rendering options hash. (Something for the wishlist..)
            Anyway.. I tested the model's entities collection on a new model, and it does not (normally,) contain the reference to it's Sketchup::RenderingOptions instance. Perhaps you've found a bug?
            Just to be safe, I would suggest typechecking each member of the entities collection while iterating to test that it is indeed a subclass of Sketchup::Drawingelement before calling any method on the object, such as .layer() in your example above.
            Inside your entities iteration loop:
            # ents= model.active_entites
            # or the entities of a group or component
            ents.each do |ent|
              if ent.kind_of?(Sketchup;;Drawingelement)
                # process for export
              end # if
              # else ignore the object
              tomasz
              Is it repeatable ?
              I am testing Thea Exporter SU2TH.
              The problem is that the error is not repeatable.I haven't discovered a certain pattern that leads to the appearance of 'strange' objects among entities. When such an unexpected entity appears it leads to a failure of an export.
              There is nothing unusual in files.
              It is strange. I started to set up a traps in my code to hijack such a 'foreign entities', but I am not able to guard all the code.
              I have noticed that those errors appear on MACs only (so far). I work primarily under Win. I have to spend more time on MAC to figure out what is going on.
              Thank you Dan for all suggestions. I will give them a try.
              My intuition tells me that there might me a 'leak' in SU 8 on MAC that allows such a behavior.
                Dan Rathbun
                Just a reminder (for anyone reading,) that we should not change entities when iterating the C++ entities collection. (Strange things can happen... items can be missed, or be processed more than once, etc.)
                If you need to change entities, then make an array copy to iterate:
                ents = Sketchup.active_model.entities**.to_a** ents.class
                Array
                Although an exporter usually should not be making changes to the model.
