    Set page print to landscape?
    9 Posts 6 Posters 4.0k Views 6 Watching
      CalypsoArt
      Is there any way to set SU to always have the print to landscape? I almost never print in Portrait. Each document I create I always have to go into print setup and switch the default from portrait to Landscape. I've tried setting in the template but new files revert to portrait. I'd prefer not to set it in the printer as my other apps mostly need Portrait.
      • Jim PatrickJ Offline
        Jim Patrick
        In Windows, SketchUp prints to a printer, not to a format. If you object to the extra clicks when you print, then create a duplicate printer that prints to landscape instead of portrait.
        1. Open the printers and faxes folder and right click on your printer, in this example 'HP100'. Select Properties.
        2. Click on Ports tab, look for the port, something like "USB001" "Virtual printer port..." . Write it down.
        3. Start the Add Printer wizard, and on the port drop down select the exact same port above.
        4. On the driver page, select the printer (if displayed) or put in the printer's driver disk.
        5. At the 'replace or use the installed driver' prompt, use the installed one.
          -- It is your call whether to make this 'new' printer your default printer.
        6. In the printer's folder, rename the printer to something like 'HP100 landscape' or 'SketchUps printer'
        7. Right click on the printer, select Printing Preferences.
        8. Make Landscape the Printer Orientation, click on Apply then on the OK button. Just clicking the 'OK' button doesn't always change it permanently.
          lettow88
          Under the File tab go to Print Setup (not print or print preview). There should be general options including page orientation.
            slbaumgartner
            This works, but the setting is not "sticky", at least on Mac. You have to repeat it every time. SketchUp does not appear to save a default page orientation.
              driven
              @slbaumgartner said:
              ...not "sticky", at least on Mac. You have to repeat it every time.
              @Steve, if you select the 'Save as Default' in the 'Setting' dropdown it will stay 'sticky'...
              always has for me at least...
              john
                slbaumgartner
                john
                what "setting" dropdown? Dropdown when you do what in what context? I don't see any such thing where I am looking? Thanks, Steve
                  driven
                  click this
                    slbaumgartner
                    @driven said:
                    [attachment=0:34oacki3]<!-- ia0 -->option_dropdown.png<!-- ia0 -->[/attachment:34oacki3]
                    Thanks, john - don't know why I never found that! Steve
                      RandyMurray
                      @driven said:
                      [attachment=0:2der91j6]<!-- ia0 -->option_dropdown.png<!-- ia0 -->[/attachment:2der91j6]
                      I have not seen this window before. Can someone tell me where in the menu structure it can be found?
                      Thanks,
                      Randy
