    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 498.0k Views 108 Watching
      DavidATCW
      Hi All,
      New the SU but finding it very useful.
      Thanks to Tak2hta for the BST plugin. I looks realy good.
      I'm using SU8 Pro on Window 7 OS.
      In the PlugIns menu under building structure tool I don't seem to have the 'Add New Profile'. The tutorial video seems to indicate it should be there??
      Appreciate any help.
        tak2hata
        I update this in Sep 05,2012.
        Bugfix about extending to face with selecting single bst entity.
        Hi,Sumaster.
        Adding toolbar like previous version has not done well yet.
        I gave priority to correction of a bug and update.
        wait while.
        Hi,david.
        "Add new profile" was disable since version1.0.
        Because the adding to CSV with ruby script has problem.
        The text code is defferent between languages.
        So the character peculiar in the language included in csv will be modified strange when ruby overwrite the csv file.
        Please edit CSV file with application like Excel or open office calc.
        Thanks.
        by TAK2HATA
          DavidATCW
          Hi TAK2HTA,
          Thanks for the reply.
          I presume modifying CSV file allows new sizes for existing profile to be added. This is not what I want to do.
          Like CTMan I would like to add new profile shape for beams, similar to CTMan's PFC profiles. Instrucion on how to this would be apprecated. We need to be able to customise to get the most out of this realy useful plugin.
          • beginnerB Offline
            beginner
            Hi Guys,
            I would like to draw your attention to the 'shapes' in tak2hata's plugin - look at the Class SHAPE and the profiles defined as *.SKP files.
            You can draw any complex shape as long is contained within single face - sample below.
            Regards, SU 'beginner'
            • sumasterS Offline
              sumaster
              @tak2hata said:
              Hi,Sumaster.
              wait while.
              Hi Tak2hata,
              wow nice update . . . . πŸ‘
              Extend to Face tool is working perfectly . . . . but
              Extend to Structure is not working properly . . .
              CHK
              I add some items in plugin menu . . . πŸ˜‰
              please add all previous item in plugin menu
              tst_main_menu = UI.menu("Plugins").add_submenu("#{langconv( 'BS Tool - 1.0' )}")
              tst_main_menu.add_item("#{langconv('>> Extend to Face')}") { Sketchup.active_model.select_tool TST1_class_extend_face.new( false ) }
              tst_main_menu.add_item("#{langconv('>> Extend to Structure')}") { Sketchup.active_model.select_tool TST1_class_extend_str.new }
              tst_main_menu.add_item("#{langconv('>> Growup to Face')}") { Sketchup.active_model.select_tool TST1_class_grow_face.new( false ) }
              tst_main_menu.add_item("#{langconv('>> Combine Each')}") { Sketchup.active_model.select_tool TST1_class_chamfer.new }
              tst_main_menu.add_separator
              And thank you so much for this plugin . . . . πŸ˜„
              i use your plugin daily . . . .
              its save my basic modeling time . . . too good . . . .
              Thank you,
              SUmaster
              • V Offline
                victor hugo
                Does anyone know where to find more RC_WALL options for the BST, when I installed it (which is very useful BTW) it only shows 4 options?
                Thanks.
                  CTMan
                  @tak2hata said:
                  Hi,CTman.
                  You are welcome!
                  If you upload the PFC profile file here , I will create link to your post in top of thread.
                  Your PFC profile file will help users of BST!
                  Hello Tak2hata - please find attached csv file for British Steel Beams and Columns
                  Hi,Sumaster.
                  I also checked the bug.
                  I will fix the problem within several days.
                  And I will update here.
                  Thanks.
                    tak2hata
                    Hi,CTMan.
                    I add link to your reply in the top of thread.
                    Thanks a lot for uploading your profile list of UK STEEL.
                    Channel([) have tapered flanges when the schema is like "[-100x50x5x7.5x8x4"
                    Channel([) have not tapered flanges when the schema is like "[-100x50x5x7.5"
                    So If you want to not tapered flange Channel,the schema is like "[-AxBxCxD".
                    Hi,sumaster.
                    "Extend to structure" tool works extending the structure to the other structure.not to face.
                    extending to structure.
                    Using "Extending to Face" to extend like this picture takes time and effort.
                    So "Extend to Structure" exists for that purpose.
                    I see the "undo" problem.
                    I will fix it few days.
                    Thanks.
                    by TAK2HATA
                    • sumasterS Offline
                      sumaster
                      @tak2hata said:
                      Hi,CTMan.
                      Hi,sumaster.
                      [attachment=0:165mbbk2]<!-- ia0 -->extending_to_structure.JPG<!-- ia0 -->[/attachment:165mbbk2]
                      Thanks.
                      yes
                      and another problem facing here . . .
                      i upgrade your new version but when i OPEN my OLD version file means (i was working your old BS tool) and exend to face and other 3 tools are not working good . . .
                      Pleas CHK
                      Thank you,
                      SUmaster
                        tak2hata
                        @sumaster said:
                        yes
                        Pleas CHK
                        Hi,Please upload your data include problems.
                        The part to limit the problem entities.
                        by TAK2HATA
                        • sumasterS Offline
                          sumaster
                          @tak2hata said:
                          @sumaster said:
                          yes
                          Pleas CHK
                          Yes . . .
                          Please CHK the Compound wall . .
                          Sept11 2012 _3 (For Tak2hata) .skp
                          Thank you,
                          SUmaster
                            tak2hata
                            Hi,All.
                            I update to version1.2. in Sep17,2012.
                            v1.2:2012.09.17:
                            Bugs? fixed.and Improves.
                            #Fix:Undo when Multi(Extend/Chamfer/Grow).
                            #Fix:Undo when change properties of many entities.
                            #Fix:(Extend/Chamfer/Grow) Structure entity which have devided side by user.
                            #Improve about create slab.
                            Hi,Sumaster.
                            In your file ,there was no compound wall.
                            But the wall's edge was cutted by your manipulation.It do not good for "Extend tool" in previous version.
                            It was improved in this ver.
                            Thanks.
                            by TAK2HATA
                            • sumasterS Offline
                              sumaster
                              @tak2hata said:
                              Hi,All.
                              v1.2:2012.09.17:
                              Thanks.
                              Hi Tak2hata
                              Thanks you πŸ‘ πŸ˜‰
                              And I'm CHKing Now
                              @tak2hata said:
                              Hi,Sumaster.
                              Thanks.
                              Oh. . . .
                              and here the new tool get random color
                              how i fix the color means ( Walls get White, Steel Member get Medium Red, . . etc )
                              Thank you,
                              SUmaster
                                tak2hata
                                Hi,all.
                                I attach CTMan's UK Steel pflist file on top of this thread.
                                It will helps Building structure tool users.
                                Thanks.
                                by TAK2HATA
                                  SUFractal
                                  I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
                                    tak2hata
                                    Hi,Sufractal.
                                    In my enviroment,"Steel Column" shown from "North American pflist" no problem.
                                    Check the line include "##" in the csv file, If you edited it.
                                    "##STEEL_COLUMN" is needed.
                                    so, send to me your profile list or upload here it.
                                    and I will look it.
                                    Thanks.
                                    by TAK2HATA
                                    • sumasterS Offline
                                      sumaster
                                      HI ,
                                      How i fix the color of BST wall . . . ?
                                      now its get random color . . .
                                      Thank you,
                                      SUmaster
                                        SUFractal
                                        @tak2hata said:
                                        Hi,Sufractal.
                                        and I will look it.
                                        Thanks.
                                        i believe I used the correct text in the file?
                                          tak2hata
                                          @sufractal said:
                                          @tak2hata said:
                                          Hi,Sufractal.
                                          and I will look it.
                                          Thanks.
                                          I tested it working fine.
                                          Steel Column shown fine.
                                          I judge that it is fine by looking only that picture.
                                          The last advice I say is "Change Profile list path" and select it again.
                                          The information about this problem is too small.
                                          Is there anyone had same problem?
                                          and please reply here.
                                          Thanks.
                                          by TAK2HATA
                                          • H Offline
                                            hygicell
                                            excellent tool, but not (yet) working for me:
                                            I cannot find an installation manual
                                            nor a user manual
                                            and where do I put the .csv files?
                                            please help
                                            Frank
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
