    [Plugin] Component Properties
    10 Posts 8 Posters 20.1k Views 8 Watching
    • thomthomT
      Overview
      I find the Component Browser awkward to change a component's properties - so I made this little utility that let you change the properties from the context menu.
      Select only one component to access the menus.
      Access
      Right-Click-Component > Component Properties
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (v2.0.0)
      http://sketchucation.com/pluginstore?pln=tt_comp_prop
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_comp_prop.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      • honoluludesktopH
        honoluludesktop
        Very nice tt.
        • Didier BurD
          Didier Bur
          Hi TT,
          As the title says, are you really back in 2010 ? ๐Ÿคฃ
          DB
          • thomthomT
            ๐Ÿ˜ณ
            I liked 2010... holding on to it for as long as I can. ๐Ÿ˜‰
            • bagateloB
              bagatelo
              OMG! Only thomthom!!! Fantastic.
              • B
                Ben Ritter
                Thomthom, thank you again.
                Ben
                • tt_suT
                  tt_su
                  Good suggestion. Added to the issue tracker: https://bitbucket.org/thomthom/component-properties/issue/1/allow-multiple-instances-to-be-changed
                  • JQLJ
                    JQL
                    hi there,
                    thanks for another awesome plugin=)
                    a improvement suggestions -> make it work with multiple selected components ๐Ÿ˜ƒ so we could tick p.e. shadows face sun for multiple components at once ๐Ÿ˜ƒ
                    Thomthom,
                    I love this plugin of yours but I guess you didn't find time to work on this suggestion.
                    It would be great if you could make it!... and, while at it, I'd also have a FR for you:
                    When choosing one component (or multiple by the above request) and you choose the component option cut openning, would it be possible that your plugin could auto select glue to any too? Then, if we wanted it to glue to specific planes, we could select that option.
                    Now your plugin is very handy for one property and one component. This is the kind of property that when you want you have to have another property chosen for it to work.
                    Thanks and best regards,
                    Joรฃo
                    www.casca.pt
                    Visit us on facebook!
                    • B
                      bsfranza
                      hi there,
                      would be supercool if we could select several different components and apply attibutes to them at once.
                      muchas gracias
                      • B
                        bsfranza
                        Oo - i have to up this once more ๐Ÿ˜„ make the magic work on multiple components at once! ๐Ÿ˜‰
